question about water injection
Old Jun 4, 2006 | 02:45 PM
japspec's Avatar
Talking question about water injection
Hi ya'll. I just installed my Coolingmist W/I kit. I verified that it works and I'm happy with it. Now here's my question, I'm trying to install a LED light that I want to illuminate when I'm spraying, do I tap into the no.3 side of the boost switch and to ground or somewhere else? Any help would be appreciated. Thanks in advance guys.
Old Jun 4, 2006 | 02:53 PM
BLitzed33's Avatar
Just tap into the switched power side of the pump, and to ground, at least thats the way I would do it. So when the pump recieves power to turn on, it will feed your led light power as well. Terminal 87 on your relay....
Old Jun 4, 2006 | 03:02 PM
japspec's Avatar
After reading the schematic, it does makes sense to tap into terminal 87. Thanks alot for the info.
Old Jun 4, 2006 | 03:07 PM
BLitzed33's Avatar
No problem, glad to help. what boost and rpm are you having it inject at, and what size jet did you use?
Old Jun 4, 2006 | 03:24 PM
japspec's Avatar
I got the single stage kit and the boost switch is set at 10 psi, I didn't know that I could set it with rpm's too. The jet size is whatever came with the kit. The person that I talked to in Coolingmist, I think his name is (Bryan?), he's the owner, said that he'll send me the right nozzle size after I told him my HP.
Old Jun 4, 2006 | 03:31 PM
BLitzed33's Avatar
Cool, no you cant set it via rpm, only boost, but was wondering when it came on for you as far as rpm's ( as boost comes on at different rpms with different setups) Cool, have fun.
Old Jun 4, 2006 | 03:33 PM
japspec's Avatar
Thanks again bro for the help.
Old Jun 4, 2006 | 05:09 PM
dhahlen's Avatar
FD Under Construction =P
You can do it super pimp like Trevor and Jarret did for my ride =) My A/C LED illuminates when it's spraying. It's pretty clean and original. But that LED sure gave Jarret hell! LOL
Old Jun 4, 2006 | 05:28 PM
japspec's Avatar
I bet it did! Thanks though, but I think I'll stick to a simple LED light on the shift column
rotor_veux
Sep 3, 2015 07:10 PM
