my fan wont shut of
Old Jun 2, 2006 | 07:37 PM
RX7RACERFD's Avatar
Angry my fan wont shut of
my damn fan does not go off when the car is turned off it will run till the battery dies. it has a new relay any idead on what to check
Old Jun 2, 2006 | 07:45 PM
Mahjik's Avatar
Mr. Links
Arrow
Try this thread:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/weird-issues-cooling-fans-431345/
Old Jun 2, 2006 | 08:19 PM
Jose Feliciano's Avatar
chosen 1
if it has a relay then the relay is stuck open change it...
Old Jun 2, 2006 | 08:27 PM
SAiamNE's Avatar
Pull the fuse until you figure out is wrong.
Old Jun 2, 2006 | 08:57 PM
Kento's Avatar
2/4 wheel cornering fiend
Not necessarily. You can check by pulling the relays and testing them, or having someone listen carefully to the relays when the battery is connected.
If all of your relays are new, you probably have a grounding issue somewhere in the wires leading to the relays. You'll need to isolate it, but you'll need to be careful doing it, as some of the wires leading to relays are pulling some current.
squirrels
Sep 1, 2024 09:52 AM
93FD510
Oct 1, 2015 02:00 PM
rattlehead
Sep 25, 2015 10:55 PM
