help !! colant buzzard wont shut off!!
Old Jun 2, 2006 | 02:23 PM
GreenMean937's Avatar
its a rx7 not a miata!!!
yeah i was driving my car the other day and the add colant buzzard went off and 3 days later tis still on and im getting tired of having the music on so loud....
i check the gauges and all 4 temp gauges i have are all reading the same well below any danger levels .. i checkd the actuall coolant and its good ... i guess i just want to remove the buzzard.... were in the hell is it ?? and can i just clip off a wire or sumthing ....
anyone who know were the buzzard come from please le tme know!! thanks in advanced !!
Old Jun 2, 2006 | 02:28 PM
Force13B's Avatar
No more G6
You sure you got the fluid toped off?
Old Jun 2, 2006 | 03:45 PM
yes .... i keep checking it and its still full..... any ideas peeps??
Old Jun 2, 2006 | 04:14 PM
rx7dv8's Avatar
Keep adding coolant or distilled water....and make sure you have your heater on high.
Old Jun 2, 2006 | 04:19 PM
FD3S2005's Avatar
SideWayZ The Only Way
could it also be the caps?? and this happen with me i had a lil slit in the ast wire.. noting much but enough for air to seep out rarly any coolant.. but my buzz would go off to.. i fixed the hose and it fixed the buzz
Old Jun 2, 2006 | 04:26 PM
ive been checking .. still cant find anything wrong .. do any of you guys know were the actuall buzzard is coming from ??something you aan unplug or sumthing ?
Old Jun 2, 2006 | 04:36 PM
rx7dv8's Avatar
Dont disconnect the buzzer....fix the reason why its going off. Trust me,....you overheat your car 1 time....and youll eat a coolant seal. Which = Rebuild
Old Jun 2, 2006 | 04:48 PM
SammyD's Avatar
check your oil level!
Old Jun 2, 2006 | 04:50 PM
i seriously thingk its a faulty wire ... and i got the pfc the bosst controler the stock meter and a aftermarket metering telling me that the temp is cool .... i have a rradiator and a fan mod.. i doubt ill turn on ... and i dont drive the car often so when i do drive i check the water and oil ALL the time .... i jsut need a quick fix for now ...
Old Jun 2, 2006 | 05:08 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
I think your problem might be the fact that the wire is already disconnected...I'm pretty sure the wire needs to be grounded to stop buzzing. Basically, when the sensor touches water/coolant it grounds and doesn't buzz, and when it doesn't touch water/coolant it starts buzzing because it's not grounded anymore. Make sense?
The wire comes off the harness behind the PS pump/Dipstick area, mine always gets disconnected when I change my plugs/wires and it starts buzzing...sometimes the old crispy wires can break. Check it out and let us know.
Old Jun 2, 2006 | 05:19 PM
ill try that right now ... thanks for the sugestion ..
Old Jun 2, 2006 | 05:21 PM
bajaman's Avatar
Constant threat
OH! buzzer
I think there is a test for the sensor outlined in the Service Manual.
Old Jun 2, 2006 | 05:24 PM
Mahjik's Avatar
Mr. Links
GreenMean,
The buzzer isn't for high coolant temps, it's for low coolant level in the t-stat housing. Open up the t-stat housing (when the motor is cold so you don't get a hot coolant bath) and verify that the coolant level is near the top. The sensor is in front of the t-stat housing.
Old Jun 2, 2006 | 05:26 PM
damm .. no go i grounded it off and still the same thing ..... it might be broken or cut from farther under the intake manifold...... does that same wire go all the way to the interior ?? or is it connected to the ecu??
Old Jun 2, 2006 | 05:27 PM
yeah majik i have tried that and there is suficient colant in there ....
Old Jun 3, 2006 | 06:09 AM
FD Rey's Avatar
I brake boost
Ground the brown and white wire, if I remember correctly, coming off the harness on the driver's side of the car. It takes a second to eventually turn off but it will. Just tap into it and ground it.
squirrels
Sep 1, 2024 09:52 AM
93FD510
Oct 1, 2015 02:00 PM
vish86
Oct 1, 2015 10:04 AM
rattlehead
Sep 25, 2015 10:55 PM
Monsterbox
Sep 11, 2015 03:29 PM
