Greddy FMIC install
Old May 31, 2006 | 09:13 PM
Quickfini's Avatar
Greddy FMIC install
Hey everyone,
I'm currently in the process of installing my Greddy 2row. This subject's been covered several times before, and I did a lot of searches, but I still have some questions.
I already checked out Tom94RX7's site (http://czfitnessproducts.com/tom94RX...tall_Pictures/), but he got rid of his AC, so he didnt have to deal with relocating that. I also checked out Nocab's site, since that's what everyone used before, but it's currently down. I PM'ed Nocab directly, but still no response.
Soooo, my question is. How do I relocate the AC condensor? Does it end up sitting completely vertical behind the radiator?
And also, what am I supposed to do with the PS hard line? I know Greddy gave me a replacement one, but I read some people didn't have to use it.
Any help would be greatly appreciated. Thanks!
Old May 31, 2006 | 09:37 PM
FLA94FD's Avatar
I assume you mean the AC condenser, in my case its mounted horizontal with the tray removed. Up there were you are I would mount it in front of the radiator like the stock setup.
Old May 31, 2006 | 09:41 PM
rynberg's Avatar
Why on god's green earth would you do that?
Old Jun 1, 2006 | 02:45 AM
Quickfini's Avatar
Yah I read others doing the same thing as you with the AC condensor located horizontally.
According to the Greddy instructions, are you supposed to locate it in front of the rad at a slight angle?
Old Jun 1, 2006 | 02:57 AM
Rocking Rotary's Avatar
Mine is in there in the stock location. Just have to pull and bend a little.
Old Jun 1, 2006 | 08:18 PM
FLA94FD's Avatar
I know your position on this and your first hand experience with road hazards. My local tuner has built many FD's with setup with no problem and the cars run cooler. My setup works like stock in traffic and I have none of the FMIC overheating issue with no additional ducting. Highway temps on a hot Florida day are lower than the stock setup.
When and if my scoot style hood arrives I'm going to see if we convert it to V-mount setup and get the undertray back on the car. I hate the lag associated with FMIC setup and the attention that it draws.
To directly answer the question it works and from what I've read here better than most other FMIC setups albeit with some risk.
Old Jun 2, 2006 | 07:17 AM
rosrex7's Avatar
its hard to see but mine is right infront of my radiator its a lot of pushing and bending but it fits.. it pretty much sits straight up ..
Old Jun 2, 2006 | 11:43 AM
Quickfini's Avatar
In a lot of the engine bay pics I've seen, no one uses the rad relocation brackets that come with the kit.
I guess it doesn't fit with a thicker rad, since my relay box won't fit between the frame and the rad. I'll have to fab up my own.
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Clacor
Aug 14, 2015 09:17 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
