stupid boost gauge question
Old Feb 15, 2002 | 10:14 PM
2000Ultra150's Avatar
Does anyone have quick easy place to wire an autometer boost gauge to? I assume that the white is a ground and the black goes hot? It was installed but the light does not work. I assume that it has one. Thanks
Old Feb 15, 2002 | 10:20 PM
skunks's Avatar
I'm a CF and poop smith
black is ground and white is hot, but i dont think it reall matters if your only wiring up a light
Old Feb 15, 2002 | 11:07 PM
got it half wired, but where is the easiest place to plug the hot wire into for it to work with dash lights? Thanks!
Old Feb 16, 2002 | 01:51 AM
c00lduke's Avatar
what i did was "rip" the center consol cover off and and tap into the wires going to the light for the ash tray. ran it down behide the pillar and then up above the steer collum and then through the very corner by you right knee into the area with the wires.
If you have any question call me 9134321031
~Luke
Old Feb 16, 2002 | 02:57 AM
rynberg's Avatar
I've heard a better alternative to the ashtray light is to use the headlight retractor switch, since it lights up and is much closer to the A-pillar. Anyone have any experience using that instead?
Snoopy FD
Dec 8, 2015 01:45 PM
TerryD
Aug 23, 2015 07:40 AM
