Pulling counter weight, What to use? Don't have specific tool.
Old May 22, 2006 | 09:38 PM
FC3S Murray's Avatar
5 and counting.
What have you guys used to pull the counter weight. No tool store has one specifically made for the rotary. I have to replace rear main seal.
Old May 22, 2006 | 11:03 PM
5 and counting.
anyone?
Old May 22, 2006 | 11:12 PM
Boostmaniac's Avatar
I used a pulley remover that I got from either pep-boys or autozone. Worked like a charm.
Check the FSM and you can see how it is supposed to be removed. I can't remember if I used the one with teeth on it or the one where you thread two bolts through to pull it off. One of them definitely worked really well though.
Old May 22, 2006 | 11:13 PM
royaltrex7's Avatar
if you can find me a place to buy a 2 1/8 socket ill send you a puller all i used was a disk i drilled holes into to hold it straight and then some on the out side to put longer bolts into to push it off
Old May 22, 2006 | 11:33 PM
Russ-R's Avatar
sears
Old May 22, 2006 | 11:35 PM
5 and counting.
I tried a harmonic balancer puller and the threads started to stretch. I have to do it with the engine in, will that pose a problem. Not much room and im am tall.
Old May 22, 2006 | 11:42 PM
Roen's Avatar
The Silent but Deadly Mod
racing beat has a tool, i don't know where exactly it is on there website, you should take a look. It's most likely under the flywheel section.
Old May 22, 2006 | 11:43 PM
5 and counting.
thanks
Old May 22, 2006 | 11:54 PM
SirCygnus's Avatar
whats going on?
wow... i just pulled mine off. after i beat it with a hammer.
Old May 23, 2006 | 12:00 AM
5 and counting.
just bought the tool from racing beat. only 18$, goota love that shop!
Old May 23, 2006 | 10:41 AM
hornbm's Avatar
FD > FB > FC
just smack in hard with a rubber mallet, it will come off
Old May 23, 2006 | 10:59 AM
5 and counting.
lol, tried that. hard to get a good angle when you are hunch over under the car in the transmission shell. It would be no problem if engine was removed. thanks for the "tip"
streetlegal?
Mar 17, 2022 02:46 PM
Microtech
30
Apr 23, 2016 06:37 PM
