Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D map needed for reference
Old May 22, 2006 | 07:02 PM
RacerNo39's Avatar
hey guys thanx for reading. im getting my car tuned june 1st. i wanted to take a map with me just incase/for info or watever. the guy said hes worked with wolf b4, but incase, u know how that goes, i just wanted to take a map with me so he can look for reference. ive got a 89 t2...street port, t3/t4 hybrid...apexi exhaust (which i hate) greddy fmic..hks bov...warlboro pump 93 oct....550 prim/720 2ndaries weekend driver basically...maybe sum on weekdays...looking for 350-400rwhp
Old May 23, 2006 | 01:50 AM
Jyst4fun3's Avatar
If you give Chris Greena a call.. he is the Wolf USA owner here in the states and talk to him more about what it is your lookin for .... im sure he would be glad to help you ...
Wolf EMS USA
Chris Greene
(916) 729~5554
or Wolfusa@sbcglobal.net
Old May 24, 2006 | 07:30 AM
Michael Smith's Avatar
Talking
You may find this a good start Your crank angle sensor will be different I have a modified CAS it was used in a V3 Wolf it uses 550/1000 injectors you will have to watch the 57% load point as I am leaning it out there at the moment. The Ignition is conservative. Also pwm idle control. I have a hybrid and 3 inch large extendport. As you can see it is not all that old it is a little behind where my car is at ths time but it will drive ok.
Cheers
Michael Smith
P.S. us at your own risk
Old May 24, 2006 | 06:14 PM
RacerNo39's Avatar
thanx for the help jyst4fun3 and Michael. Michael, u have very good post and replys on this site. u have been very helpful and u r very knowledgable. i can take it from here now..haha. thanx again guys.
Old May 29, 2006 | 04:08 AM
Cheers RacerNo39, If you get a chance could you post your dyno figures and AFR's and maybe your map if it is OK. Now I know that you have spent good money on getting it tuned so if you don't want to post your Map thats fine too! So don't feel pressured. It would be good to see the dyno data though.
Cheers
Michael Smith
Old Jun 26, 2006 | 06:18 PM
Node's Avatar
you will more than likely need both larger secondary injectors and a turbo to reach 350-400rwhp.
160lb/min ford injectors are dirt cheap, as for the turbo. worry about what it makes after you dyno
is it a compressor wheel only hybrid, or compressor wheel and housing?
I'm thinking about a wolf for my hi compression streetported 13bt w/ h-trim hybrid.
-Ben Martin
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
