my car doesn't want to start...please help!
Old May 22, 2006 | 03:36 PM
ryan1985gslse's Avatar
Newbie
Unhappy my car doesn't want to start...please help!
Hey all,
Went to start my 85 gsl-se the other morning and it was turning over but just kept chugging away and not firing up.
took the distributor off and it spins and sparks, i smell fuel when i open the engine (so i'm assuming the fuel pump is working) and the starter is chugging...anyone know what else it could be?
I saw someone mention the "ignitors" or something along that line... please help!
Thanks in advance..
Old May 22, 2006 | 07:08 PM
aussiesmg's Avatar
Thunder from downunder
Do a search on ignitors, search button top right of this page.
Do a search on fail to start also.
Old May 22, 2006 | 07:43 PM
trochoid's Avatar
Old Fart Young at Heart
If the plugs are sparking, ignitors are good, probably flooded.
Old May 22, 2006 | 08:15 PM
Kentetsu's Avatar
Yep... A search will turn up plenty of threads on how to "de-flood" an SE... Welcome to the forum btw.
Old May 30, 2006 | 08:38 AM
Newbie
well... I got it de-flooded so thank you for the advice!
Now that it started, there are more problems. It was idling rough for a while and then just died on me. I can still start it but it just sputters a bit at very low rpms and when you rev it and let off the gas, it dies.
Also, the coolant was extremely warm after the engine was only running for a few minutes..
Could I have messed up something electrical without knowing it or am I looking at some major repairs here?
It ran perfectly before the flooding happened...
Thanks
~Ryan
Old May 30, 2006 | 09:34 AM
aussiesmg's Avatar
Are you getting spark to all of the plugs?
What do the plugs look like?
Old May 30, 2006 | 12:50 PM
Newbie
they look pretty good. only put about 4000 miles on these plugs at the most. i cleaned them off with a wire brush while i was de-flooding... should i try new ones?
im pretty sure i put them back in the right order..
3 2
4 1
right?
Old May 30, 2006 | 01:53 PM
rOtAryIsbEttEr's Avatar
voo doo witchdoctor
3 2
4 1
right?
the dist cap should be labled L1, T1 and ect. match up teh wires like this:
T1 T2
L1 L2
if thats not the correct firing order you can come to texarkana and kick me in the nadslol
welcome to the fourm, btw
Old Jun 14, 2006 | 02:46 PM
Newbie
thanks for all the help so far!
Its not the sparks as far as I can tell.
The car started up fine when I tried again after letting it sit for a few days. It did the exact same thing again though. It started fine, idled high to warm up, and then as soon as the high rpms at startup dropped off, the rpms slowly choked down and it died. i started it again just fine and then died...
also, just as i mentioned above, after only running for 5 minutes, the engine coolant hoses and radiator were blazingly hot...
any ideas?
Old Jun 14, 2006 | 03:25 PM
tigermack's Avatar
CPS Motorsport
I did that too, I think it's still flooded. I tried a couples times before I get it running normal.
Old Jun 14, 2006 | 03:27 PM
trochoid's Avatar
Go here and down the page are some links for your SE. https://www.rx7club.com/1st-generation-specific-1979-1985-18/1st-gen-rx-7-faq-page-237777/
DO NOT let your engine get that hot!!! That is the quickest way to blow it there is, and it can take only once to require a rebuild, this is a rotary, not a piston.
Address the cooling issue first, you cannot troubleshoot an overheating engine. Start with checking the coolant level, the waterpump and fan clutch. Change the thermostat with an OEM Mazda one only. Flush and fill with fresh coolant.
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
cam_7779
Aug 18, 2015 07:48 AM
armans
Aug 15, 2015 09:08 PM
