Sponsored by: CARiD
help with trans. please,please,please
Old May 21, 2006 | 09:52 PM
quincey's Avatar
Exclamation help with trans. please,please,please
i have a 89 convertable auto with 98,000 miles on it when it gits warmed up while driveing and stop then go again the trans. acts like it is slipping only during shifting it pulls fine but during the shift it has like a sliping going on ...ive changed the filter and it did not help ,can anyone tell anything..and if i can disconect the kickdown on it ? it wont do it if you back off the throttle at the time it shifts...
Old May 22, 2006 | 07:36 AM
SureShot's Avatar
Seduced by the DARK SIDE
What you describe sounds like your tranny is getting near its rebuild time.
After getting a quote for an automatic tranny overhaul, maybe compare it to a manual tranny swap.
Old May 22, 2006 | 05:44 PM
quincey's Avatar
it pulls fine it dont act like its sliping when you push the gas only during the shift or if you kick it down in passing gear it acts like its in neutral then you have to back off and it shifts back intoo drive its fine
Old May 23, 2006 | 08:30 AM
SureShot's Avatar
You did the best thing you could by changing the filter.
When engaging a gear, the actuator servos have to go almost full stroke before what’s left of the brake band finally grabs the clutch.
That’s the time delay you’re seeing.
Check out the transmission section of the on-line FSM at the link in my sig.
You may download & print whatever you need.
Old May 29, 2006 | 12:19 PM
spot_skater's Avatar
The Cause of Death
Think it could just be the clutch packs being worn?
Either way, if it is an internal transmission problem, you might just want to go 5 speed.
Also...check the line pressure. If you can jack it up a bit, you can get it to shift harder.
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
HIMNI Racing
Jun 21, 2003 12:31 AM
HIMNI Racing
Apr 22, 2003 02:51 AM
tatersgravy
18
Apr 11, 2003 03:47 PM
