83 RX7 won't crank
Old May 17, 2006 | 10:09 PM
DavidMyers53's Avatar
83 RX7 won't crank
I just bought an 83 RX7 with 117,000 miles on it that has been sitting in a shed since 93. The owner had cranked it and it would run but not idle. He installed a new fuel pump and filter, but that didn't help. I rebuilt the carb (Nikki), put in new plugs, wires, distributor cap, rotor, air filter, and changed oil and filter. It seemed to be killing the battery (new, cheap one) when I tried to crank it so I replaced the alternator. After adjusting the idle mixture and speed it was running fine. I poured a can of flush in the radiator and let it run for awhile, then let it sit overnight. Pulled the radiator hoses off and replaced them, and poured in new anti-freeze. Tried to crank it, it turns over fine, but will not fire. It's getting gas to the carburtator and has spark. I followed the trouble shooting guide in the Haynes manual and it seems to be the air vent solenoid.
Anyone had similar problems?
Any place other than a dealer to get an air vent solenoid?
Thanks in advance for any help you can give.
- David
Old May 17, 2006 | 10:16 PM
aussiesmg's Avatar
Thunder from downunder
Try a search on deflooding procedure, its easy to flood a rotary and has to be manually deflooded.
thecody59
40
Aug 23, 2015 06:41 PM
PhillyFC
Aug 21, 2015 06:36 PM
Sharkbait24
Aug 12, 2015 10:36 AM
