Mikuni 44phh photo's. What goes where?
Old May 17, 2006 | 11:43 AM
timmybighands's Avatar
Bad A55ed Hands
Since a few guys said pics would be easier, I thought I'd post them. I think I'm going to pre-mix regardless of wether it's got nipples for the OMP or not, so I'll just cap them.
Which are my idle adjustment screws? Which are A/F ratio, etc?
Also, any ideas on mounting the throttle linkage would be cool.
Old May 17, 2006 | 11:44 AM
Bad A55ed Hands
Bottom of the carb... are these the OMP nipples?
The nipple on the firewall... is that for fuel return?
Old May 17, 2006 | 11:45 AM
Bad A55ed Hands
On the fuel line T fitting, I just capped one side. Is that acceptable? How about when I'm running 15psi of pressure?
Old May 17, 2006 | 11:50 AM
aussiesmg's Avatar
Thunder from downunder
Hey guy, thos two on the base are for coolant to warm the carb, I don't use them or have them blocked off, ignore them basically.
I have my T fitting set up exactly like yours.
Do you have a clearer shot of the linkage?
Steve
Old May 17, 2006 | 11:52 AM
aussiesmg's Avatar
Idle adjustment is on the opposite end of the shaft that is the throttle linkage, it is simply an external bolt that restricts the throttle return.
Do you have adequate return springs?
To use the stock OMP you would just wire it to that same end of the throttle shaft so it opens under throttle demand, but as you know I prefer premixing.
Old May 17, 2006 | 11:58 AM
aussiesmg's Avatar
https://www.rx7club.com/1st-generation-specific-1979-1985-18/post-your-mikuni-carb-pics-525625/
Here is the link to my install
Old May 17, 2006 | 12:26 PM
Bad A55ed Hands
Thanks Scott... I've been reading on that one for a bit now.
Old May 17, 2006 | 01:12 PM
LokiRx7.1's Avatar
Hey another 5 bolt Mikuni
Old May 17, 2006 | 04:15 PM
trochoid's Avatar
Old Fart Young at Heart
Uh, I didn't do anything, Steve is the one you should thank. Your linkage has been cobbled by a po. If the screw at the bottom of the arc still comes out, lay the stock throttle cable in the groove with the end of the cable just past the screw, reinstall the screw and tighten down gently. That extra lever is not stock.
Old May 17, 2006 | 05:33 PM
inuissus_cendi's Avatar
I can answer the easy question!
yes, the nipple on the firewall is your return line.
Old May 17, 2006 | 05:38 PM
trochoid's Avatar
Crap, I missed that question. Deadhead the fuel system, don't run a return line, it does nothing but screw up fuel pressures.
Old May 17, 2006 | 11:43 PM
Bad A55ed Hands
Oops - I meant Steve. Lol sorry. Anyway, thanks for the info. I think that lever and bolt are welded on permanently. I'll tinker with it more in a bit.
Shouldnt I be running a return line with an EFI pump and mallory FPR?
Old May 18, 2006 | 12:58 AM
trochoid's Avatar
I forgot you were going boost. Yes, run a return off the 4309. You can deadhead at the carb or run 2 fuel suppy lines to the tee on the carb. Makes no difference.
Turblown
Sep 30, 2015 05:58 PM
