LSD change
Old May 16, 2006 | 11:11 PM
cptpain's Avatar
Torqueless Wonder
LSD change
I seached but to no avail...i have started to feel the LSD on the SE is worn out...im not looking to rebuild the LSD..im looking for a new LSD so can drift....and no i wont weld an open lsd... is the FC lsd interchangeable? if so i want to get a KAAZ 1.5 lsd for the fc to fit my SE...someone help me with this!
Old May 16, 2006 | 11:20 PM
Tranquil's Avatar
Wankle Waffles
I'm not sure, but I think I might've read somewhere that the Miata aftermarket LSD's will fit into a first gen RX-7, maybe. I honestly don't know and someone else might be able to say I'm wrong.
Old May 16, 2006 | 11:25 PM
aussiesmg's Avatar
Thunder from downunder
Miata drivetrain link
http://members.aol.com/solomiata/Drivetrain.html
Old May 16, 2006 | 11:29 PM
Pele's Avatar
Right near Malloy
FC diff but NOT the gearset.
Miata Gearset AND diff...
Old May 16, 2006 | 11:33 PM
cptpain's Avatar
Torqueless Wonder
i just want the diff....i like to keep the ratio..how much for the KAAZ 1.5 for fc?
Old May 16, 2006 | 11:40 PM
81gsl12a's Avatar
blown up motors
boocoo money....its like 900 i beleave
cheers PaTricK
Old May 17, 2006 | 08:24 AM
Tranquil's Avatar
Wankle Waffles
hooray I was right!
Its actually cheaper to purchase a Kaaz LSD in 1.5 or 2 way for $600 (lowest price I've found) and get it shipped from Japan than purchase it from an American outlet and still have it shipped from Japan.
Old May 17, 2006 | 08:40 AM
Pele's Avatar
Right near Malloy
Nuts to that. Miata Torsen for $250 AND you get a better gearset. You can't beat that with a stick.
Old May 17, 2006 | 09:21 AM
Siraniko's Avatar
RX for fun
$250? I have been lucky then. $25 for a set of 4.44 ring and pinions from kia and 4x4 mazda p/u.
Old May 17, 2006 | 09:44 AM
Pele's Avatar
Right near Malloy
Ah but no torsen differential.
Old May 17, 2006 | 12:46 PM
cptpain's Avatar
Torqueless Wonder
i want to keep the gear set the same cause i do a lot of highway driving and need the fuel economy for the drive to the drift events...all i want is the LSD...if anything i want to have 5th gear very long so that when im cruising at 80mph my revs will be well below 3k not like now where its more like close to 4k..
Old May 17, 2006 | 04:40 PM
Tranquil's Avatar
Wankle Waffles
Well from talking to a few guys over the phone today the Miata set might be better than the FC because the Miata weighs about the same as our cars. The FC is heavier, obviously.
Old May 17, 2006 | 04:48 PM
Siraniko's Avatar
RX for fun
Siraniko's Avatar
RX for fun
im a cheap ***.
Old May 17, 2006 | 04:50 PM
aussiesmg's Avatar
GSL is 3.909 which would marginally lower your RPM at 80 mph and get you a littler better gas mileage. SE is 4.1 by the way.
Old May 17, 2006 | 06:39 PM
Slammed_GSL's Avatar
Cool Miata Kaaz/Moser axles
Per conversation with Driftalanta
"Dont know the part number. I called Newport exotic cars, talked to the guy. All i knew was 1.8L miata diff fit. So i bought the 1.5. Its not torsen its clutch type. If you call the guy he set you up w/ the correct diff. If you can wait till monday . I will look in my tool box at work, and see if the part number is one the manual.
I would also suggest the moser axles, I have bent probably 4 sets of stock ones. The moser are only 350 shipped. I have a invoice number you have them copy the order. All you need to have them do is make them 12mm shorter my order. I went longer so i could custom tailer the length w/ the diff out to get as much spline in the kaaz.
part number on manual
DBZ1810"
Moser axles are GSL-SE spec to match the Miata Kaaz splines.
This was the info I got from Adam on his Kaaz install.
Old May 18, 2006 | 01:53 AM
Hyper4mance2k's Avatar
The Shadetree Project
Top!
One thing to know is that the Miata Torsen is going to be break happy at anything over 250whp. I know miata guys who will not run them with sticky tires and anything close to 200whp. Torsen diffs are not as strong as LSD's. So for clarification I can sawp a FC LSD with my gears into my 84 housing and the axles will pop right in??
Old May 18, 2006 | 06:53 AM
Siraniko's Avatar
RX for fun
LSD maybe but not the entire 3rd member since the FC's ring is 8" right like the TII?
Old May 18, 2006 | 06:59 AM
trochoid's Avatar
Old Fart Young at Heart
FC NAs are 7", TIIs are 8".
Old May 18, 2006 | 07:03 AM
Siraniko's Avatar
RX for fun
thanks
Old May 18, 2006 | 08:36 AM
Pele's Avatar
Right near Malloy
Originally Posted by Hyper4mance2k
Top!
I'm not running turbo. I doubt I'll be pushing 250 HP. Plus I'm not a drag racer.
Old May 18, 2006 | 11:36 PM
cptpain's Avatar
Torqueless Wonder
so if im pushing over 250hp i need some custom work done right? i dont want to go too extreme cause then i would go for a ford 8.8 and thats not very drift friendly
EDIT: i like to drift and drag...so i need a setup that will keep these things and still be driveable!
Old May 19, 2006 | 01:14 AM
blwfly's Avatar
kiwi from downunder..
since we talkin bout 3rd members can i swap a 82 gsl 3rd member in to my 83 se axel?
do i need the drivesharft
Old May 19, 2006 | 01:39 AM
steve84GS TII's Avatar
FB+FC=F-ME
Torsen LSD = great road racing diff,smooth N/A power delivery is what it likes
Stock type 4 pinion clutch LSD = great drag race,high torque launching diff....I.E turbo
The nature of the stock clutch LSD makes it grip harder,the more HP you pump into it.Even when worn out or lacking preload,they will hook up when the power kicks in,its just how they work.They cab be treacherous too due to lockup under decel and chatter when driving normally.But they are far more robust than the complex Torsen type LSD.
No such thing as an 83 SE....84-85 only.
All the 84-85 cars had bigger axles,so no its not a direct swap.You can do it,but youll have to rebuild the diff with 84-85 side gears,hardly worth it.
If you are talking about an 83 LE,then yes you can swap the 82 GSL pumpkin right in.Youll need to run the 82 driveshaft or change the flange to match the 83's driveline.
Old May 19, 2006 | 01:44 AM
blwfly's Avatar
maybe its a 83 s i dont know how the modles go but its 83
thanks for qwick respone
hopefully the wreckers will let me take it
is the pumpkin a different ratio or same as the 83s?
