NGK R6725-105 spark plugs
Old Feb 14, 2002 | 11:38 PM
A-Spec's Avatar
anyone use these? I've posted a thread in the 3rd gen but it seems no one is interested or have never used it.
I came across it reading some of the Japanese owners' pages and I found that they sell it at rx7.com and mazdatrix also. Has anyone used these? this is a single electrode plug so I think it would give a more precise timing.
tks,
David
Old Feb 14, 2002 | 11:53 PM
A-Spec's Avatar
also what was the other plug that rice racing suggested? B10EV?
tks,
David
Old Feb 15, 2002 | 04:25 AM
RICE RACING's Avatar
I have used those and found them excellent for racing, however I have also used the B10EGV and they perform as far as I could tell to the same std as the "full" race plug at a fraction of the cost.
The RA series should not be used with high lead fuel such as aviation gas as they ground and center electrode do pick up a lot of depositis from the lead.
Old Feb 15, 2002 | 06:42 AM
SPEED_NYC's Avatar
RX-Parts
RICE is back! where ya been?
Old Feb 15, 2002 | 10:34 AM
crispeed's Avatar
'Tuna'
He's been creating a monster!
crispeed
87TII
9.20@150mph
Old Feb 15, 2002 | 10:42 AM
BOOSTD 7's Avatar
Persona non grata
Where can I get the B10EGV's?
Old Feb 15, 2002 | 12:40 PM
A-Spec's Avatar
tks rice racing, you are right the R6725 are quite pricy...what's the difference between the b10egv and the R6725? they both use the single ground electrode? what other difference is there? is the B10egv shorter?
a good place to get them is http://www.monarchproductsinc.com/ngk.htm
they have pretty much everything that's available out there, good prices too, I think.
TKS!
David
Old Feb 26, 2002 | 05:17 PM
A-Spec's Avatar
B10EGVs are made by NGK also, they are also racing plugs.
Mine just arrived today, the ceramic seems to be a little shorter than the BUR plugs but the electrode portion is the same length.
Rice racing, what should I use as gap on these? I know there was a thread about it before but there seems to be a mess up between the metric and english system. Can you tell me which is correct?
tks!
David
PS I will try the regular and the B10EGV when I tune the power FC on a dyno and report back if there was any difference.
Old Feb 26, 2002 | 07:22 PM
007007's Avatar
thats a reasonably cold plug. Anyone have problems with them fouling during "normal driving"?
Old Feb 27, 2002 | 12:19 PM
Jedon's Avatar
Slave2TheFD
Do I need an upgraded ignition system to drive colder plugs? I'll be running a single @ 15-17psi ~430RWHP.
Thanx!
-Jedon
Old Feb 27, 2002 | 02:41 PM
A-Spec's Avatar
I have 9s now...seems to be ok...I'll be running the 10s daily drive, so I'll report back on how well it works. I've heard that some ppl run 10s all the time without trouble, but I don't think they see winter weather.
no you don't need iginition upgrade, the colder plug just dissipates heat more than the 7,9s.
David
Old Mar 1, 2002 | 10:47 PM
A-Spec's Avatar
umm ok I tried to install the B10EGVs today...how do you tighten it? the plug is a little shorter so the nut part is in the engine block so I can't get to it with my socket...Rice racing, how do you tighten it??
tks,
David
Old Mar 2, 2002 | 07:07 PM
amemiya's Avatar
David
I am running bur9eq's now and it drops down to 20 degF out here does temp outside make a difference?
Old Mar 3, 2002 | 01:31 AM
spyfish007's Avatar
Yellow Dragon is no more
gap plug to 0.02 .... you will need a special socket or turn normal one down on a lathe or grind down the lip on the block to get them to tighten up. You can do it without doing this but you will hate it ....
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
