Bad water seals?
Old May 15, 2006 | 11:34 PM
shotglass_10's Avatar
Bad water seals?
my car wont start it is an 85 GS. im getting good compression in the front rotor, and okay compression on the rear rotor, fuel and sparkare great too and i have cleaned the spark plugs several times with carb cleaner and it didnt help , but she wont run just crank, i had a guy who owned an rx-7 tell me that my problem was the water seals and that i should try towing it to start it but i want to know from people who know what their doing before i try this. also when its turning over the carb spits back does this mean its time for a rebuild? any input would be greatly appreciated Thanks!
Old May 16, 2006 | 12:02 AM
trochoid's Avatar
Old Fart Young at Heart
Carb spitting does not mean it needs a rebuild, can be an indicator possibly. Go ahead and push/pull start. Try brake cleaner and compressed air to clean the plugs.
Old May 16, 2006 | 12:05 AM
Keegan's Avatar
my friend is got the same pro just rebelt the carb and it stoped
Old May 16, 2006 | 03:30 AM
Paradox's Avatar
backyard tuner
probably not the best way to clean a plug but i just used a clean up brush on mine to see if it'd help at all, and well it worked wonders.
Old May 16, 2006 | 08:14 AM
mazdaverx713b's Avatar
Have RX-7, will restore
could be something wrong with the carb. it could possibly be frozen internally or your needle could be stuck.
Old May 16, 2006 | 10:48 AM
TomH's Avatar
If the engine is turning over fine, but just not starting, what's the point of towing?
Old May 16, 2006 | 03:09 PM
trochoid's Avatar
Towing raises the rpms hugher than the starter can, this will often overcome flooding by increasing spark without adding more fuel.
Old May 16, 2006 | 05:48 PM
if the towing start works do i have to do anything else to the motor or am i good to drive?
Old May 16, 2006 | 08:30 PM
trochoid's Avatar
Since my psychic powers are down today, I guess you will have to try it and find out.
SCinfidel
Sep 8, 2015 05:36 PM
