Hesitation
Old Feb 14, 2002 | 03:41 PM
1QWKRX7's Avatar
Hesitation
Can anyone tell me or help me with this problem? My car hesitates when im at WOT from any rpm any when I look at my A/F meter it goes off the scale on the lean side but if I let off the gas a little and give it half or 3/4 throttle its fine. I checked all the hoses for cracks nothing. I just did the TID mod because it was cracked? I grounded the boost sensor. And I installed new plugs and wires. Would a seal on the turbo cause this? I need to rebuild it or upgrade but want to fix this first. Anything I should look for? What should I do? Please someone help I hate getting beat by slow *** cars.
Old Feb 14, 2002 | 10:05 PM
1QWKRX7's Avatar
Somebody.
Old Feb 14, 2002 | 10:12 PM
hanman's Avatar
Are you sure that you have adequate fuel supply?
i.e. fuel pump, fuel filter etc?
hanman
Old Feb 14, 2002 | 10:35 PM
1QWKRX7's Avatar
I have 850cc secondaries, but dont know how old they are. I have the stock fuel pump and I dont know when the fuel filter was changed last. Could that do all this to my car?
Old Feb 15, 2002 | 11:08 AM
1QWKRX7's Avatar
^^^BUMP^^^
Old Feb 15, 2002 | 11:16 AM
Chance's Avatar
Maybe you're running too rich. My car had serious hesitation until I leaned it out, up to -20% on my SAFC. It's still running a little rich, but it doesn't hesitate nearly as bad as it used to. I see you have 850cc secondaries. From what I can tell, that's a little much for your mods. I'm not sure, just a thought.
Old Feb 15, 2002 | 11:38 AM
1QWKRX7's Avatar
But when I give it full throttle the a/f meter goes off the scale on the lean side.
Old Feb 15, 2002 | 11:41 AM
Taranis's Avatar
With 850cc secondaries, you shouldn't be leaning out. My guess is you either have a clogged fuel filter or you need to upgrade to a TII fuel pump. When was the last time you changed the filter?
Old Feb 15, 2002 | 11:53 AM
1QWKRX7's Avatar
Fuel filter, dont know if it was changed yet. I do have a TII fuel pump. How much are fuel filters? Are they easy to change?
Old Feb 15, 2002 | 12:03 PM
Taranis's Avatar
Very easy. Open the hood and look down the driver's side next to the firewall all the way at the bottom. Two bolts and two hose clamps. About a 20 min job.
Fuel filters aren't that much. I don't think they're any more than $10.
Old Feb 15, 2002 | 12:17 PM
1QWKRX7's Avatar
Could a dirty or old fuel filter cause my problem?
Old Feb 15, 2002 | 04:48 PM
Taranis's Avatar
Absolutely. Clogged filters can only put out so much compared to new.
Old Feb 15, 2002 | 04:52 PM
RETed's Avatar
I noticed you had a TID mod.&nbsp Is your airflow meter in the correct position?&nbsp This should be with the black plastic cover up or the cross-ribbed side up.&nbsp If it isn't, this can cause hesitation...
-Ted
Old Feb 15, 2002 | 07:57 PM
hey got the same prob on my 88 its was the AFM on mine changed it out havent had a prob since it would run rich at idle and half throttle but when WOT it would like lag alot and go to lean until i came off of WOT
Old Feb 20, 2002 | 10:51 PM
FDxc's Avatar
hey 88vert what kind of mods did you do to your car? pm me.. i need some ideas.
Old Feb 20, 2002 | 10:55 PM
SoloIIdrift's Avatar
check the TPS maybe, make sure it's still good?? I dunno
rgordon1979
40
Mar 15, 2022 12:04 PM
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
lnlreaper
Sep 27, 2015 09:59 AM
