how much boost can they handle
Old May 8, 2006 | 09:40 PM
gray_86's Avatar
ThE_CaRbOn_GuRu
how much boost can the stock twin turbos from a 1993 fd handle
Old May 8, 2006 | 09:46 PM
Mahjik's Avatar
Mr. Links
A few people have used them up to 17 PSI (about the limit of the stock map sensor). However, as you increase the boost, you decrease their lifespan.
Old May 8, 2006 | 10:15 PM
I'd say 15 psi is about the 'safe' limit for a streetcar, in my opinion.
Old May 9, 2006 | 01:49 AM
prescription 7's Avatar
RX7club addict
No more than 15psi, 12 on the safe side
Old May 9, 2006 | 11:18 AM
dgeesaman's Avatar
All of these answers are assuming you have the proper fuel and tuning mods in place. Stock cars really shouldn't go anything over stock boost (10psi)
Dave
Old May 9, 2006 | 05:23 PM
gray_86's Avatar
ThE_CaRbOn_GuRu
Dave
that is what i was thinking because this is actually in a second gen
N/A
Old May 9, 2006 | 05:26 PM
dubulup's Avatar
development
N/A
Nuvolari's Avatar
Veni, Vidi, Vici
How many miles on the turbos ?
If you have old- not rebuilt or new ones they may boost 13psi+ but not for long...old technology was replaced for a reason.
Old May 9, 2006 | 05:54 PM
ehos's Avatar
Passion
Turn up the boost controller ALL the way. Then when the engine blows, turn it back a quarter turn.
Old May 9, 2006 | 06:01 PM
SLOASFK's Avatar
Top's always down
same question, 99spec turbos?
Old May 9, 2006 | 06:53 PM
Mahjik's Avatar
Mr. Links
Same answers.
Old May 9, 2006 | 07:26 PM
gray_86's Avatar
ThE_CaRbOn_GuRu
they are off of a 1993 rx7 so i dont know what would have changed but i know it will be quick they really are just untill i get it all setup and then i will upgrade to bigger and new
Old May 9, 2006 | 10:57 PM
so you're just going to slap fd turbos onto your fc? have fun with that one.....let us know when it's working
Old May 9, 2006 | 11:03 PM
Stanello's Avatar
backslash beanbagrace
Sequential too I bet.
Old May 9, 2006 | 11:10 PM
drama's Avatar
DRAMA
how much boost
Your not a rotary guy if you have ask how much let alone trying to say your going to stick a set of fd turbo`s on a second gen 6 port. Your better off going with a supercharger They actually make a somewhat bolt -on kit I`am sure thats more up your alley. I`am sorry to be a ******* but its the truth about what you posted here.
Old May 10, 2006 | 01:28 AM
Tanjo's Avatar
Royale with cheese
well, if he had a manifold, and he was running non-seq, he might be able to get it working...
Old May 10, 2006 | 01:54 AM
xblazinlv's Avatar
Ferrari Red Hotness
If he set them up non-sequential he should be able to do it.
Old May 10, 2006 | 10:51 AM
gray_86's Avatar
ThE_CaRbOn_GuRu
i know it is not a bolt on deal and i am new but i can fabricate anything and i have for this i am not just slapping it on and hoping it works i am trying to do some research here and ****** keep telling me the same f***king thing it isn't bolt on well obviously it is not or more people would have already have done it. and i don't want to have a bolt on because then my car will be just like anybody elses that has a factory made kit for it. and the only reason i ask this is because i did not know what the FD ran for stock boost i dont own an FD i have an FC i always thought it was 7psi
Old May 10, 2006 | 11:47 AM
dgeesaman's Avatar
The FD runs 10psi stock, and runs lower compression rotors than a N/A FC.
I'm far from an expert on this subject, but I believe running N/A rotors with turbos is a bad idea. You'd need to rebuild with the more suitable rotors.
Dave
Old May 10, 2006 | 11:52 AM
dubulup's Avatar
development
^naw, just make sure you have plenty of fuel (maybe some 4x720cc top feeds will get you safe 7psi (WG spring)...good pump also), EGT and WB...keep your AF and EGT in check and you'll have a damn quick N/A-T.
will this be NON-SEQ? if not Saxyman on this forum has made a custom solenoid rack you could fit.
Old May 11, 2006 | 04:14 PM
gray_86's Avatar
ThE_CaRbOn_GuRu
it will be non seq'
Old May 11, 2006 | 07:16 PM
DrunkenBowler's Avatar
Why fab. up something that wasn't meant to be there. Couldn't you just buy an upgraded turbo kit, and not worry about non-seq. I would just get a single if I were you. Tune it properly and away you go. But, to each his own.
Old May 11, 2006 | 09:06 PM
twin fd3s's Avatar
Talking
dont you me mean a half turn
Old May 12, 2006 | 05:32 PM
gray_86's Avatar
ThE_CaRbOn_GuRu
Why would i want to have the same thing as everybody else who has bought a kit when i can make it different and then nobody will have the exactly the same thing and what is the point in getting someone else to make something for you if you have to do that your not a real car guy
Old May 12, 2006 | 05:40 PM
ehos's Avatar
Passion
OH DOU!
Yeah, sorry for spreading misinformation. It's half turn after you blow your engine!
I think it's in the Faq, silly me for not searching!
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
