Is 550cc/1680cc enough for a T51kai
Old May 6, 2006 | 08:30 AM
Hi..
I did just buy a fuel rail with 1680 cc for secondarys and I thought I could put the 850cc in the primary, but it is not a perfect fit. Is it ok to use the 550cc and the 1680cc for a HKS T51R kai and aprox. 450 hp..??
Thanx
Old May 6, 2006 | 09:36 AM
dhahlen's Avatar
FD Under Construction =P
Will a walbro - no.
That pump is going to max out around 400hp.
I run a cosmo TT pump which flows a bit more than a walbro. I had 850 (cleaned and tested at 874cc, and 1680cc injectors)
I maxed out my pump around 430hp. My injector duty was hitting 100% at 19psi but I was also spraying methanol...
If you want 450hp, add another walbro and you'll be good for tons of HP. But 450hp on a single walbro is pushing it.. the KAI just requires too much air/fuel to boost.
I am in the process of throwing in another pump, and both are wired for 12vdc. I'm expecting over 600hp on my next tune.
Old May 6, 2006 | 11:26 AM
hi..
I will add another fuel pump, but is 550/1680 ok..??? Or should i find a 850..??
Old May 6, 2006 | 11:31 AM
dhahlen's Avatar
550/1680cc should be fine for 450hp.
Old May 6, 2006 | 12:52 PM
books's Avatar
Why don't you use Max Cooper's site to estimate your fuel needs?
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
Old May 6, 2006 | 12:54 PM
LUPE's Avatar
Old May 6, 2006 | 09:45 PM
dhahlen's Avatar
Originally Posted by LUPE
LOL - you go ahead and laugh... haha... by the time I get there, you'll either have:
1.) Blown your motor
2.) Made 700hp
3.) Did both
Anyway, I'll make the power.. especially if I have the methanol come on at 20psi and cool down that intake charge, w00t.
LOL
Claudio
Aug 14, 2009 11:15 PM
2Lucky2tha7
Oct 16, 2007 02:15 AM
1.3Ldreamcar
Sep 9, 2007 02:05 AM
DiaperBoy
Nov 18, 2001 02:23 AM
