Mounting a BB turbo on an angle
Old May 6, 2006 | 02:23 AM
R.P.M.'s Avatar
Likes to swear....alot
I'm building a custom up-pipe for a WRX that will be using a GT30R BB turbo, it seems the only way to have the turbo correctly fit with the I/C piping will be to mount it on a fairly steep angle.
Will there be any complications doing this? Like oil not properly being fed to the bearings?
Old May 6, 2006 | 02:36 AM
TT_Rex_7's Avatar
A-spec appears to angle the GT42R in their kit, so I guess it's not an issue. However, it's not that all that "steep" of an angle. I would say it depends on what kind of angle we're speaking of here...
https://www.rx7club.com/spec-tuning-154/gt42r-kit-any-questions-ask-here-466010/page2/ (scroll down for pictures)
-Alex
Edit: I would try e-mailing/calling Garrett, Turbonetics, or Precision. I'm sure any one of them can give you a solid answer.
Old May 6, 2006 | 02:53 AM
R.P.M.'s Avatar
Heres a pic of a test fit, it sits on a pretty good angle.....
Old May 6, 2006 | 03:15 AM
TT_Rex_7's Avatar
That looks pretty damn steep. I'd definitely contact Garrett to see what they say.
Here's a site a came across on google.
http://www.ultimate-racing.com/Produ...RXStage5.shtml
Maybe the pictures on this site will show you a better location for the turbo.
Hope this helps!
-Alex
Old May 6, 2006 | 11:00 AM
R.P.M.'s Avatar
What could go wrong with the turbo if it was mounted like this?
Thanks TT_Rex_7, those guys are using the stock top mount I/C, whereas I need to leave room for the FMIC piping that comes off the blue silicon coupler in the pic above. Plus the power steering lines and other crap are right in the way.
Old May 6, 2006 | 12:59 PM
Zero R's Avatar
Just in time to die
15* or less is what garrett will tell you, the 42R pics are misleading only the turbine housing is clocked not the CHRA. I had a up-pipe that might have worked for you but it is long gone. That turbo will feel laggy on that car if it is a 2.0 Not too bad but definitely lose on the bottom end.
Old May 6, 2006 | 06:14 PM
R.P.M.'s Avatar
The customer is hoping it will be laggy...he doesn't want to replace trannies every week....neither do I LOL.
It is a 2.0L, I also had to hack up a $2500 Maximum Works header to make the up-pipe work for this.
Nobody answered my question.....whats the worst thing that would happen if its mounted at an angle greater than 15*. I'm curious....would it smoke? work fine? burn out quick?
Old May 6, 2006 | 07:13 PM
JZ 97 SS 1500's Avatar
What happens is improper loading of the bearings will cause premature wear. Its not as bad with DBB's since you have no thrust, but it will still wear. Also draining will become an issue
Old May 6, 2006 | 07:20 PM
Zero R's Avatar
Just in time to die
^^Exactly^^ Premature wear and drain issues which can lead to smoking for sure. Another thing is oil coming out the ring gap in back and you will have oil coming out the DP.
-S-
Old May 6, 2006 | 07:41 PM
R.P.M.'s Avatar
Hmmmm yeah thats kinda what I was afraid of.....I guess we'll see how it goes.
Thanks for the info guys!
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
