Haltech 4 wire 02 wires
Old May 3, 2006 | 10:07 PM
gonzz's Avatar
4 wire 02 wires
I just got a 4 wire o2 to hookup to the E6K. Howdo i know what wire is what on the 02? thanks
Old May 3, 2006 | 10:18 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
If you download (or have) your E6K manual, look for the O2 sensor connections, there is a nice detailled graph showing you the different ways to connect a narrow band O2 sensor.
Old May 3, 2006 | 10:25 PM
gonzz's Avatar
Originally Posted by Claudio [url="#"
RX-7[/url]]If you download (or have) your E6K manual, look for the O2 sensor connections, there is a nice detailled graph showing you the different ways to connect a narrow band O2 sensor.
Thanks
Old May 3, 2006 | 10:46 PM
EFI Tech Wannabe
Does that answer your question?
Old May 4, 2006 | 12:21 AM
gonzz's Avatar
A little but not completly.. The 4 wire o2 plug I have is labeled 1,2,3,4. I will cut the plug off and solder in the wires. The problem is how do i know what each wire is on the 4 wire o2. I just want to make sure i get this right.. Everything else is pretty much done on the install..
Old May 4, 2006 | 12:52 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
just use a single wire.
the benefit of a heated o2 sensor is it warms up very quickly, so the car can go into closed loop mode quickly.
but oh yea, you can't run that lean at idle, so a 4-wire is useless over a single wire. $18 from autobone will solve your problems
Old May 4, 2006 | 09:40 PM
EFI Tech Wannabe
The 4 wires on the sensors are usually 2 black (or 2 white) a grey and a brown (or a blue or violet), the 2 wires with the same colors are always the heaters, and you have to find out which is the ground and wich is the signal wire.
Then just follow the diagram.
I prefer to use the 3 and 4 wire sensors because they start working a lot faster than the single wire.
Old May 5, 2006 | 12:31 AM
gonzz's Avatar
The wire colors are as follows.. 2ea white, 1ea gray and a black or dark blue. How can i tell which is ground. use a ohm meter against the wire and the body of the sensor? Thanks for all the help..
Old May 16, 2006 | 10:47 PM
gonzz's Avatar
Ok.. so the 2ea white are heater wires.. How do i tell which of the other two is the ground?
Old May 17, 2006 | 09:56 AM
EFI Tech Wannabe
Its likely that the grey wire is the signal, so the black (or darkblue) is the gnd. Connect 1 heater with that ground to the Haltech gnd pin, the grey to signal, and the other white to the 12v pin.
Old May 17, 2006 | 11:48 AM
buy a sensor from autozone--they come with instructions. whrite them down, then take it back.
Old May 17, 2006 | 07:04 PM
gonzz's Avatar
thanks
Old May 18, 2006 | 08:10 PM
eo2am's Avatar
RIP Creamsicle!
Thats a easy way on figuring it out. LOL
Old May 20, 2006 | 12:50 PM
actually, i bet the autobone doods probably wouldn't mind you jotting down the directions so you don't even have to buy it.
Old May 20, 2006 | 01:04 PM
gonzz's Avatar
I went there and the paper don't tell you any wire colors..
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
