NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
auto to 5 spd swap...
Old May 3, 2006 | 09:57 PM
Mechanic's Avatar
THE Mazdabator
has anyone done this, and how hard was it to be exact. if you've done this before, would you like to help me out if i can buy a clean shell in auto?
Thanks, if there are tips to this swap, please let me know i dont wanna kill my self.
Old May 4, 2006 | 07:59 AM
ramello's Avatar
hey where abouts in NY???
i did the swap before.....its not terribly hard can be done in a full day (about 10-12 hours) if you have all the parts ready to go.........
if your nearby (im in Albany) i wouldnt mind popping over and helping you out.......
im sure youve read some writeups about it so that would help in tracking down what parts you need.........
the hardest ones to come by would be the pedal assembly, and the tranny crossmember support, everything else you can buy from like mazdatrix or someone if you cant find it in a scrapyard or for sale used
as far as the tranny support, rotaryressurection used to make them and you might message him about making you one or buying one from him
but let me know
Old May 4, 2006 | 08:09 AM
ROTARYROCKET7's Avatar
my car was auto now its stick. Not terribly hard. But your gonna need a new crossmember made cuase the auto tranny sits further back and the manual is shorter so ure gonna need to get two steel bars welded to the manual crossmeber and holes made thru it so it can bolt into the auto holes.
Jason NYC
Old May 4, 2006 | 01:01 PM
I have a 5 spd tranny that was rebuilt 9k miles ago, and also a 4.1 torsen diff available if you need them. For bulky heavy parts like a tranny/diff, local sale is always the easiest. PM me if you're interested.
Old May 4, 2006 | 01:15 PM
Tofuball's Avatar
Jesus is the Messiah
Hey, if he doesnt want it, any chance I could trade you some parts for that 4.1 Torsen? (TII diff + gear w/ FD torsen I assume?)
Old May 4, 2006 | 08:39 PM
Mechanic's Avatar
THE Mazdabator
Guys i just purchased a VERY mint auto fc that dont start the guy said "sounds like it lost compression maybe a seal or something went" the car has 57k miles or so on it, ny inspected in feb, white, only thing is the drivers door looks a little dented nothing harsh, tapping on the metal, nothing sounds bondoed... going to carfax it soon, but left deposit for it oh yeah, 91 everything original coupe model...
guess how much...
and if i told you on aim, it dont count!!!
Old May 4, 2006 | 10:33 PM
Mechanic's Avatar
THE Mazdabator
so all I need is is 5spd tranny... cross member... is there anything with wiring? counter weights? anything special with clutch and flywheel? or is it just drop out bolt in and go type of stuff?
Old May 4, 2006 | 11:53 PM
you need the manual flywheel. You gotta do a lil wiring like tieing up the neutral switch so that the car starts etc. Just the welding of crossmember is gonna be the main issue
Jason NYC
Old May 5, 2006 | 10:49 PM
ramello's Avatar
message rotary ressurection about the cross member he has a good writeup on how to use the auto one and also he makes custom ones as well
you can prolly jsut buy it from him
dont forget about pedal assembly since your auto doesnt have a clutch pedal
and possibly new driveshaft?
when i did my swap i was goin from n/a auto to t2 5spd so i needed to do the whole rear end....so unsure about the driveshaft.....cuz i think its shorter on the auto cars
Old May 7, 2006 | 01:13 PM
Mechanic's Avatar
THE Mazdabator
price of vehicle $600
4 Spark plugs $24
Car running... priceless...
seems like injector stuck open, idles at like 1500 rpm in park/neutral, in drive or reverse its at like 500 rpm ROUGH too... stalls out if i turn on ac or drive then stop.
think i gotta stick a set of injectors in there... -=\
the car is pretty smooth at 1500 rpm idle.. and i saw my gas needle drop 1/2 of a quarter in matter of 20 minutes or so...
pressure tested coolant held 13 lbs fine. no steam or bubbles while warming up
changed oil...
now all i need is it to run right (prob injectors) and do a 5 spd swap.
the car was painted before, OK job.. no bondo, light dents/dings here and there not noticable cept drivers door.
everything original not tampered with. only rust i saw, was surface rust at pinchers and rear lower control arms.. the underbody was lightly treated for NY winters. (originally cali car, purchased from original owner, which is an actor on "the wonder year" w/e that is... lol
a/c is ice cold too... lol. got a suspension set up comming in from Rishie for it. gonna throw the ones i got now on to my black one.
a little exhaust leak by cats... oh well...
thats basically all i checked today, everything is straight, seems like the front bumper had a little accident, everything straight capt passenger lower fender, lightly dented in.
while we tried to push the car on the tow dolly, it cracked the passenger side lower bumper... -=( and marked the drivers side lower bumper.
seems like rear hatch was replaced at one point since its black.
other than that... $624 for a running car, + gas for tow and toll for tow, a little extra for my boss to go get lunch .
anyone wanna put a word in to see what i can do about the 1500 rpm idle? am i correct on injectors..
Old May 7, 2006 | 02:52 PM
4 Spark plugs $24
changed oil...
YO did you see this car on CRAIGS list. I saw a white s5 FC automatic for sale. I was gonna buy it from the guy. He wanted $900 i told him $500 and i would pick it up this weekend then he emailed me and said it was sold. So im wondering is this the same car. The guys name was mike.
Well iim still working ou tthe lil headaches from my swap ill be def able to lend u a hand in june iight
Jason NYC
Old May 7, 2006 | 03:48 PM
Mechanic's Avatar
THE Mazdabator
Jason NYC
yeah i gave him 600... LOL
were you suppose to show up on thursday to look at the car or something, but couldnt make it?
I didnt know anyone gave him an offer, he told me i was one of the first one to contact him. lol... oh well. -=P
Old May 7, 2006 | 05:28 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
damn you guys are getting all these good deals. i found one on craiglist not too long ago and the dude said the 88 fc (not sure which model but its a n/a) saids it only cranks but wont start. and "needs some body work"...hmm flooded? he wants 1100 for it.
Old May 7, 2006 | 06:32 PM
yeah i was suppose to go thursday with ANIL (kao1tk) but then i said ill go FRIDAY cause i had late classes on thursday till like 8pm.
Man i was gonna have a ball with that FC man, he told me it didnt start and im like ***** prolly flooded so i gave him some BS like its gonna need a rebuild etc and i gotta spend 1500 outta pocket then i was just gonna go overthere cop the car then start that **** right in front of him lol
Well goood that you got the car atleast you needed it i was gonnna strip her for parts make some good $$
Jason NYC
Old May 7, 2006 | 06:33 PM
Nah SNTP they got em cheap i paid 2k for my baby but she was so ******* clean when i got her. For 3 years of me having her and her sitting for half that time, she got fucked up. But im bringing her back to life
Jason NYC
Jetlag
Sep 29, 2015 06:52 AM
