Correct GAP for B10EGV's
Old Apr 28, 2006 | 08:08 PM
dhahlen's Avatar
FD Under Construction =P
I think they are gapped .022 out of the box.
I hear .025-.030 is the rule of thumb...
Can anyone using these plugs confirm that?
Thanks,
-Darren-
Old Apr 28, 2006 | 08:10 PM
LUPE's Avatar
.032
Old May 2, 2006 | 03:07 AM
4CN Air's Avatar
DETH TRP
I've heard anywhere from .030-.035
I've run EGV's and EIX's at .032
I just pulled my 9/10 EGV setup after less than 1000miles and found a severely worn down electrode. I think the MSD box is too much for them.
Old May 2, 2006 | 06:24 AM
shawnk's Avatar
Perpetual Rebuilder
I have been running them as they come (.22) for the last 2 years - about 4 sets so far I think. I have never heard anyone talking about a different gap...What difference would you expect between .32 and .22? Power? Longevity?
Thanks!
Old May 2, 2006 | 07:52 AM
dhahlen's Avatar
Steve used .022
Old May 2, 2006 | 08:02 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
it depends on how much amp and coil you are using as well as if you are running water or alcohol as AI... you want to run as much gap as you can.
between 22 and 33
howard coleman
Old May 2, 2006 | 08:40 AM
shawnk's Avatar
Perpetual Rebuilder
Excellent info....I am running stock coils, hks twin power and 93 octane. No water, etc. What do you think I should run Howard?
What benefit does running them wider give?
What symptoms would running them too wide give?
Thanks,
Old May 2, 2006 | 09:27 AM
too wide = high speed miss
wider = equals more mixture exposed to ignition
w your setup i would run 22-25
howard coleman
NEWGENRX7
Jun 26, 2019 12:20 AM
rotor_veux
Sep 28, 2015 09:25 PM
