Need Help With Fuel System Set Up!!!!
Old Apr 19, 2006 | 04:09 PM
coolrotaries's Avatar
Hey guys,
I am currently planning out my fuel system and needed some guidence from the people who have been there already. Here it goes.
I have 1600cc injectors for the secondaries. 850's for the primaries. I also have the(rx7.com) pump installed.
I will be using the AF61 turbo. And running a Haltech E6K.
What is the shopping list I need to put together everything.
How many feet of -6 line do I need from the the pump to the rails?
Are risitors needed to run the 1600cc?
Can anyone provide any leads to sites that would carry the parts at a good price?
Any help would be greatly appriciated!!
Old Apr 19, 2006 | 08:42 PM
IRPerformance's Avatar
Sponsor
With the 1600s you should run resistors if you have a power fc. I think I remember seeing them at the rx7 store.
Old Apr 20, 2006 | 07:10 AM
Bacon's Avatar
IRS 4 Life
With the e6k you dont need resisstors, I have the same injector setup, you might want to make sure you keep an eye on fuel pressure. The rx7.com pump is decent but if your going for big hp youll need 2 pumps to keep up the flow. Thant injector combo can flow about 1.3gal per min at full duty.
I want to say youd need 12 feet or so, but im not certain. The cars only 14 and a half nose to *** so you should be fine
jegs.com
or summitracing.
Old Apr 20, 2006 | 07:58 AM
thanks guys. Its great to know that I won't be needing resistors. Alos I forgot to ask about the ignition setup. Do I need to change it for any reason?
Up to what HP is the stock Ig good for?
Old Apr 20, 2006 | 09:37 AM
Bacon's Avatar
IRS 4 Life
Everone has a different oponion, some say 20psi, some say 25. some say to use the coils from a t2 and that will be good for 25+
how much boost you looking to run?
Old Apr 20, 2006 | 10:22 AM
18-20psi for the street, maybe less
Old Apr 20, 2006 | 11:11 AM
Bacon's Avatar
IRS 4 Life
Stock ignition should hold up fine, if you want throw an amp on it. Its all in the tuning
Old Apr 20, 2006 | 12:11 PM
Thanks for the helpfull info!! If anyone has or knows of someone who is selling fittings, lines or anything else for the fuel system.
Thanks Again
Old Apr 21, 2006 | 07:45 AM
Bacon's Avatar
IRS 4 Life
WWW.Kgparts.com
Keith's da man
Engine stand ready
Aug 14, 2015 10:26 PM
