Speedometer cable -- mechanical or optical?!
Old Feb 11, 2002 | 11:41 PM
Manolis_D's Avatar
Is the speedometer cable 'pickup' point on the tranny of an FC a mechanical or 'optical' link? Looks like a fiber optic cable to me!
Anyone? (have my reputation at stake here )
Thanks!,
Manolis
Old Feb 11, 2002 | 11:42 PM
Felix Wankel's Avatar
Super Newbie
Looks like an old school drive/driven gear setup to me.
Old Feb 11, 2002 | 11:47 PM
mazdaspeed7's Avatar
mad scientist
Mechanical, its just a cable that spins to drive the speedo.
Old Feb 12, 2002 | 12:21 AM
Manolis_D's Avatar
doh!
how does it attach?
I looked at it an the transmission end of things seems to have kindof a circle with a notch cut out on it -- what engages with this?
I don't see anything sticking out of the cable end of things to engage w/ that...
Thanks,
Manolis
Old Feb 12, 2002 | 11:47 AM
mad scientist
Unscrew it. The thick end that goes into the tranny just screws in.
Old Feb 12, 2002 | 11:57 AM
Thaniel's Avatar
Re: doh!
Originally posted by piston eater
how does it attach?
Thanks,
Manolis
The cable end goes in the circle there is a flat spot kind of squished on the cable end that engages the notch. The outer covering for the cable then threads on to the tread that are on the out side of the whole thing. Typical spedometer cable.
Old Feb 15, 2002 | 01:33 PM
Manolis_D's Avatar
thanks Thaniel!
My friend just got a 1991 NA and the smog guy left the cable undone when he smogged it, so it got dragged down the freeway for like 20 miles (don't ask me how he didn't notice...).
The mazda dealer quoted like 190 bux to replace the cable... I wonder if I can do it. Anybody ever replaced it?
Old Feb 15, 2002 | 01:42 PM
RETed's Avatar
Nah, that's a load of crap!&nbsp The cable itself should be about $50.&nbsp One end goes into the back of the transmission - it's easy once you get the car jacked up.&nbsp The other end goes through the firewall and plugs into the back of the instrument cluster.&nbsp Be patient as the clip one the firewall is pretty tricky and getting the speedo cable plugged and secure takes even more patience; it can be done without pulling the instrument cluster by going under the dash, but be prepared to be laying upside-down on your back for up to half an hour!
-Ted
Old Feb 15, 2002 | 05:31 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Go used
This is a part that would be good to go used as much as new. Probably get away with $10 if go used.
SRTx781
Dec 19, 2015 07:30 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
