Sponsored by: CARiD
ecentric pully setup
Old Apr 16, 2006 | 03:09 AM
odavemon's Avatar
I received a engine without the ecentric pullys and need to determine where the timing marks go in relation to the eccentric shaft. Then install the distributor. Thanks
Old Apr 18, 2006 | 03:01 AM
john ward's Avatar
oi oi oi
is the keywayed pulley on the engine
Old Apr 18, 2006 | 04:35 AM
odavemon's Avatar
yes the keyway pulley is on the engine and I have tried all four positions on the belt pulley reseting the distributator each time but the engine hasn't fired. Suggestions?
Old Apr 19, 2006 | 10:13 AM
SureShot's Avatar
Seduced by the DARK SIDE
The main shaft pulley can only be mounted one way because the holes are not in a square pattern. The 4th bolt will not go in any other way.
I first set the shaft at TDC by spotting the apex in the exhaust port, then backing it up to the center of the housing.
Then I line up the CAS mark and stab it in.
Then to check it I turn the shaft to the timing mark, take off the CAS cover, and see if the star wheel lines up with the reluctance head.
Old Apr 19, 2006 | 04:41 PM
odavemon's Avatar
I should have done that when the reactor was off but now the engine is in the car. The 12A belt pulleys will go on in all four positions so what I need is to find TDC on the key way pulley the belt pulleys bolt to.
eplusz
15
Oct 7, 2015 04:04 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
