Sponsored by: CARiD
88 se no start after tb mod and rats nest removal
Old Apr 16, 2006 | 02:33 AM
royaltrex7's Avatar
car had a pd problem that caused an engine fire but it was put out within 30 sec. it melted 2 omp lines so i pulled the all the intake off and cleaned everything. i removed the rats nest. i also did the tb mod and ported the intake properly only 2 thousanths. reinstalled everything and started it it started out idling at 6k. adjusted the tb and got it down to 2k did not adjust tps. then tryed to move the cas but it seemed stuck. Wiggled the cas around till it would move. now that everything is back together and the cas is adjusted to factory specs it will not start. yes i have searched and checked the fuses and all the connectors everything is hooked up and no blown fuses battery has a strong 12.6 volts its brand new optima yellow top. turns over but not catching oh and it has compression on both 1 and 2
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
12abridgeport
Aug 17, 2015 06:28 PM
