what do i need to go single turbo
Old Apr 15, 2006 | 09:26 AM
dirtyjerzusmc's Avatar
The Under Achiever
i have an fd and want to go single turbo (im really interested in turbonetics), i already have a front mount, my fuel system is already upgraded, ignition. and pretty much every other bolt on imaginable. my twins are non-sequential, and im looking for the most cost effective way of converting to single. so what aside from the turbo what all do i need to replace.
Old Apr 15, 2006 | 10:34 AM
moehler's Avatar
Turbo, manifold, DP and all lines and fittings. Make sure that your upgraded fuel system is up to it (1600's and 550's/850's and a good pump). It is pretty easy if you already have every other bolt on.
Old Apr 15, 2006 | 10:59 AM
BDC's Avatar
BDC
BDC Motorsports
The most important thing is the EFI system used, DirtyJerz. Without it, it will never run the engine properly at the higher loads for any semblence of reliability.
B
Old Apr 15, 2006 | 11:08 AM
The Under Achiever
yeah i forgot to mention power fc w/controller. im tryin to hit mid/low 11's without sacrificing reliability (i put in vented hood, koyo radiator and some flex-a-lite fans are comin up). my twins are leakin oil like crazy and i know theyre not worth rebuilding, do i need single or should i stay with twins (non seq) or go with upgraded twins (which ones are good)
Old Apr 15, 2006 | 05:30 PM
mwatson184's Avatar
holley guy
Go single. As stated before; turbo, manifold, downpipe, oil lines and fittings, intercooler piping, air inlet piping/filter, and retuning.
Old Apr 15, 2006 | 06:01 PM
Turblown's Avatar
Turn up the boost
Going to need a wastegate also...
You should do clutch, suspension, and tires also...
Rotary Performance Parts
Old Apr 15, 2006 | 09:16 PM
The Under Achiever
already running act street strip clutch, unorthodox lightweight flywheel. anyway, so a single turbo upgrade wouldnt be over kill to hit 11's. i mean i hear its common on twins and i figure with all my upgrades i should have a shot. and stupid question: ii guess i cant use current wastegate, intercooler piping, 3in. downpipe/midpipe, or air intake/filter. and say i did go with like BnR or another set of twins would i need anything
Old Apr 15, 2006 | 10:29 PM
Turbo23's Avatar
Panda Bear
alot of money
Old Apr 15, 2006 | 11:43 PM
The Under Achiever
oh you mean throw some more into my RX-Money trap lol. i was hopint all i would need were the turbo and manifold seeing how everything else is aftermarket. so wats needed to go with BnR's or Enfini
Old Apr 16, 2006 | 01:18 AM
blueskaterboy's Avatar
Olympic Muff Diver
$10-15k
Old Apr 16, 2006 | 07:18 AM
The Under Achiever
Originally Posted by blueskaterboy
$10-15k
ON WHAT, the BnR stage 3 is like 2300 what else would i need to put those in, especially to reach that high of a price. and if your talking about single, i already have fmic, new fuel system, apexi power fc. so im taking i cant use any of my other stuff even though its already aftermarket (i.e. downpipe, wastegate, air inlets, etc) i was hopin to just have to buy the turbo and manifold
Old Apr 16, 2006 | 09:05 AM
BLitzed33's Avatar
Just go single as many have stated before. you are going to have to get intercooler pipes made and a greddy elbow, and fitted to the new turbo setup, block off oil return passage, etc... Most turbo kits come with the dp, manifold, wastegate, lines, fittings, etc..expect to pay around 2-5 grand just on the turbo kit depending on what you get. As far as fuel, recommend 1600cc secondary with fuel rail, 550cc or 850cc primary, upgraded pump, regulator. Another issue is how old is your motor, if its tired you might want to have it rebuilt at the same time. Going single eliminates all the vaccum mess, back pressue, and will be more efficient at making power at high boost. Then factor in the labor and tuning costs. Good luck
Old Apr 16, 2006 | 09:50 AM
The Under Achiever
54k original miles chassis/engine and ive put about 8k on the motor since the rebuild and street port. Heres every upgrade done to the car... (i appreciate everyone's help, im tryin to get this figured out before i come home from this deployment and being in another country makes it hard to research, thanx guys)
ACT Clutch
Lightweight Flywheel
Apexi Power FC
Block off Plates
Unorthodox Full Pulley
Racing Beat Dual Tip Exhaust System (no cat)
3mm Apec Seals
Down Pipe / Mid pipe combo
Nipponditso Fuel Pump
1600cc x2 (secondary)
Fuel Pressure Regulator
HKS Twin Power Ignition
G'Reddy Twin Intakes
G'Reddy 3row Fmic
Turbo XS Dual Staged Boost Controller
Turbo XS RFL Blow off Valve
G'Reddy Turbo Timer
Koyo Radiator
Heat Wrap on manifolds
Toyo Proxes 4 tires
Hawk Brake Pads
soon to come
Flex-a-lite dual electric fans
Engine Torque Damper
Rx7.com full launch kit
Here's a link to the pictures of engine
http://www.cardomain.com/ride/2241406/2
once again i appreciate everyones help on the matter, and just to clarify i can ditch all the vacum lines if i go single ???
Old Apr 16, 2006 | 11:56 AM
moehler's Avatar
$10-15k
If he blows his engine, maybe...
dirtyjerzusmc, nice car!
You car is a good candidate for going single, you have most of the **** you'll need. With all of your mods you can probably get away with <4k for everything. Good turbo kits are getting cheaper (much less than 3k depending on the kit). Conservatively figure 1k-1.5k for **** you forgot about (pipes, clutch, tuning, fuel pump, etc.). good luck.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
