What about a electric OMP (89+ T2) and a Haltec?
Old Feb 10, 2002 | 11:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
How would this be done?
Old Feb 10, 2002 | 11:55 PM
RETed's Avatar
The current Haltech E6K is not able to control the electric OMP properly by itself.
There are rumors that Rotary Performance has managed to pull this off; try get in contact with them on more info -> http://www.rx7.com/
-Ted
Old Feb 11, 2002 | 12:00 AM
MIKE-P-28's Avatar
Ok, I was cosidering maybe using the oil pressure sensor or maybe even a vacuum switch after i figured what the voltages should be. I might be able to adapt it or something?
Thanks
Old Feb 11, 2002 | 12:03 AM
RETed's Avatar
The stock electronic OMP is a quad stepper motor control - we're talking at least 4 input/signal channels to properly control such a beast.
You might want to check out the new AEM ECU, as they claim their system CAN control the stock OMP.
-Ted
Old Feb 11, 2002 | 12:12 AM
MIKE-P-28's Avatar
Ok gotcha so it changes opening and closings due to boost, load, rpm etc Thanks
Old Feb 11, 2002 | 12:14 AM
RETed's Avatar
That I can't answer if the stock system works that way, but I believe the AEM computer is able to change oil delivery versus boost and RPM.
-Ted
Old Feb 11, 2002 | 12:15 AM
cymfc3s's Avatar
I Raise Chickens
you can either pre-mix, or do what im doing. Which is use an 87-88 front cover and water pump housing with a manual metering pump.
Old Feb 11, 2002 | 12:21 AM
MIKE-P-28's Avatar
Ok sounds good, thanks guys
Old Feb 11, 2002 | 02:56 AM
von's Avatar
von
Hey.. Does the AEM ECU have the ability to get rid of the MAF sensor too. If so im sold.
Andrew7dg
Aug 6, 2017 01:41 PM
