to turbo or not to turbo?
Old Feb 10, 2002 | 09:53 PM
nashman69g's Avatar
Boost Addict
Exclamation to turbo or not to turbo?
is the housing on a nonturbo engine the same strength as the turbo housing?
Old Feb 10, 2002 | 10:51 PM
nashman69g's Avatar
Boost Addict
in otherwords, i want to see if I can add a turbo to my 90 N/A motor with out blowing any thing.
Old Feb 10, 2002 | 11:22 PM
nashman69g's Avatar
Boost Addict
how much boost pressure can it hold.
Old Feb 11, 2002 | 12:33 AM
NZConvertible's Avatar
I'm a boost creep...
Save yourself a huge amount of grief; sell the NA and buy a Turbo.
But if you're a sucker for punishment, do a seach. There's been a million posts on doing this.
Old Feb 11, 2002 | 01:13 AM
Mykl's Avatar
If you can't find a Turbo II in acceptable condition, or your car is a convertible, or you're particularly attached to your car you can grab a Jap-spec 13BT to drop in for a fairly reasonable price.
Old Feb 11, 2002 | 02:00 AM
Coolidge's Avatar
Well if you are doing a really powerful turbo engine... then it might not be all that much better to sell the NA and buy a TII. Normally when you want a turbo, it's a much better, easier, cheaper way to do it (buy a TII) but if you are going to a stand alone EMS, high boost, big power application, then you probably are just as good with the NA. Other than you will probably want to remove the 6ports.
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
