anyone regret getting a 8lb flywheel
Old Apr 8, 2006 | 10:08 AM
Rotary-Celica's Avatar
Does anyone regret running a 8lb on the street? Mainly interested in NA but would like to hear from all who are or did run a super light flywheel on the street.
Thanks
Aaron
Old Apr 8, 2006 | 10:19 AM
LUPE's Avatar
I'm selling my 9lb and putting the stock flywheel back in.
Old Apr 8, 2006 | 10:22 AM
MonkeyMagic's Avatar
Stay running...please??
why is that?
Old Apr 8, 2006 | 10:28 AM
LUPE's Avatar
Originally Posted by MonkeyMagic
why is that?
I lose too much boost between shifts.
Old Apr 8, 2006 | 11:39 AM
TEZTnTUNE's Avatar
BUILD, TUNE, RACE, REPEAT
hahahaha mechanical advantage rears its ugly head once again
Old Apr 8, 2006 | 07:04 PM
CCarlisi's Avatar
Rebreaking things
How is that??
I had a 9.5lb SR FW and really liked it. It makes a big difference in lower gears and generally makes the motor feel much more responsive.
Old Apr 8, 2006 | 10:30 PM
diabolical1's Avatar
i'm curious about this, too.
Old Apr 9, 2006 | 01:31 PM
KNONFS's Avatar
B O R I C U A
Thanks
Aaron
I don't, but I don't have a 600hp monster either; besides I really like auto xing
Old Apr 9, 2006 | 02:05 PM
Jodeny's Avatar
Indifferent
Originally Posted by CCarlisi
How is that??
Less inertia. The rpms drop a lot faster.
John
Old Apr 9, 2006 | 04:13 PM
rotarygod's Avatar
Rotors still spinning
I have the aluminum SR Motorsports flywheel and will never go back to anything else. It's wonderful.
Old Apr 9, 2006 | 06:10 PM
LUPE's Avatar
I have the SR Motorsports Flywheel I'm trying to sell because I'm going back to the stock flywheel.
Old Apr 9, 2006 | 07:34 PM
CCarlisi's Avatar
Rebreaking things
John
So don't let off as much when you shift -problem solved.
Old Apr 9, 2006 | 08:22 PM
LUPE's Avatar
I'd like to see you get behind the wheel of a fast car and try to "not let off as much between shifting"
Old Apr 9, 2006 | 09:01 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i have a os gilkin twinplate with some light wheel (9ish or 11 not sure) and with my bad syncro's.. i have to blip the throtal to get into 3 and 4th or by the time i get it into gear im at 1k rpm.. and it all happens Very quicly
however if i had a good tranny, i wouldlove my clutch
Old Apr 9, 2006 | 09:05 PM
CCarlisi's Avatar
Rebreaking things
I never had a problem matching revs with my 9.5lb flywheel at 17psi. Unless the accel/decel settings are off it shouldn't be an issue. I don't know what you consider to be fast, but remember he is asking about street driving.
Old Apr 10, 2006 | 08:20 AM
Jodeny's Avatar
Indifferent
I thought you asked for an answer , however you already knew the answer... I like the responsiveness of a LW flywheel as well, but if the car is losing traction I have to 'wait' between shifts and I lose boost as well.
John
Old Apr 10, 2006 | 04:01 PM
So it sounds like I should have no problems with a 250+ HP NA motor.
LongDuck
Oct 7, 2015 08:12 PM
