tranmission sticks in gear
Old Apr 4, 2006 | 09:56 PM
midnitetoker's Avatar
Newbie
what up peeps just joined i have a question that maybe someone can help me with. sorry if this is covered somewhere in the archives but my transmission is sticking in first gear at first it was just getting harder to change gears so i thought it might just be that i need to change transmission fluid but now i think it might be the pilot bearing going put so now im thinking it might just be easier to swap an s5 t2 into my s4 na what do u think
Old Apr 4, 2006 | 10:11 PM
Juan's Avatar
Im a tall midget.
Are you thinking about doing a full T2 swap or just using the tranny on your car? Hows your clutch pedal pressure? The best thing to do is to drop your tranny and see whats going on. Doing a T2 swap or even trying to use a T2 tranny is going to be harder and more expensive than trying to fix your current setup.
Old Apr 4, 2006 | 10:15 PM
MrFC3S's Avatar
ROTARD FOR LIFE!!!
Bump that... I think my dad said its a shifter Bushing that does that
Old Apr 4, 2006 | 10:43 PM
Newbie
well i was planning on using the t2 tranny and maybe rearend if possible but pretty sure my shifter bushing is messed up too
Old Apr 5, 2006 | 02:33 AM
Juan's Avatar
Im a tall midget.
to do that I think you'll need the following: TII tranny, driveshaft, diff, clutch w/pressure plate, throw out bearing and the list goes on. All of this would run about $750+ dollars in parts.
If your tranny is indeed bad, you can find an s4 replacement for about $100 or less. Check your clutch to see if thats not the problem. Stock clutch replacements are less than $100. Bad shifter bushings wont make your tranny stick in one gear. Even with the worst bushings Ive seen, selecting gears is still relatively easy. Good luck.
Old Apr 5, 2006 | 08:02 PM
Newbie
well i wanted to go turbo anyway and if i did i would want to do it the right way.
my shifter bushings are pretty jacked but its been like that the shifter is kind of cocked to the side they are so bad but i bought the car that way. i read on fc3s pro that the pilot bearing could fall apart fusing the engine and tranny together and 750 aint that bad if i could find a donor car that is which will be hard in san antonio, thanks for ur help
Old Apr 5, 2006 | 08:17 PM
inflatablepets's Avatar
I'd check the shifter bushings first. That's the cheapest and easiest fix. If they are worn, you will eventually have problems shifting.
Old Apr 5, 2006 | 10:10 PM
RETed's Avatar
Clutch hydraulics
pilot bearing
throw-out bearing
I would also throw some good synth lube in the trans.
-Ted
Old Apr 5, 2006 | 10:33 PM
Busted7's Avatar
Will work for horsepower
that swap requires, auto counter weights-t11 fly wheel-trannie-drive shaft and t11 diff, not to mention clutch pressure plate and bearing.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
