what should normal oil pressure be?
Old Apr 4, 2006 | 06:27 PM
wishIhadanFC's Avatar
I just finaly fixed my oil pressure gage, however since i had the needle off the gauge i think its calibrated wrong. on startup the gauge reads about 95psi, then after the car warms up it drops to about 45psi at idle. if i can get a general consensus of what average pressure readings are i can try to set the needle correctly.
Old Apr 4, 2006 | 06:30 PM
MattB's Avatar
MattB
Idle 30, WOT 60....
Old Apr 4, 2006 | 07:20 PM
Wizz's Avatar
Originally Posted by MattB
Idle 30, WOT 60....
What he said.
Old Apr 5, 2006 | 08:25 AM
V8slayer's Avatar
Tire Smoken Tandm Gambler
i 3erd that
Old Apr 5, 2006 | 09:31 AM
SystemIDx's Avatar
My **** keeps breaking.
When I'm driving around normally, mine sits around 90-100. Dunno what that means. Car drives like a champ.
Old Apr 5, 2006 | 10:17 AM
Aaron Cake's Avatar
Engine, Not Motor
This information can also be found in the Factory Service and Haynes manual.
Your oil pressure sounds fine.
Old Apr 5, 2006 | 10:27 AM
DerangedHermit's Avatar
Mine idles around 45, but sometimes when I'm cruising (~3000 rpm) it jumps to 80-90. Is this bad?
Old Apr 5, 2006 | 03:45 PM
RylAssassin's Avatar
Ted's got it all on his sight http://www.fc3spro.com/
Its supposed to be around 30 at idle and no more than 80 at higher rpm's. Although Ted mentioned that high oil pressure isint neccissarily bad...
Oh and at startup (cold) its supposed to go to like 80psi due to the bypass oil pellet (i think thats whats it called) opening to allow oil to circulate the rotor chamber.
Old Apr 5, 2006 | 05:44 PM
jgrts20's Avatar
Who are you?
30 idle and 60 driving
Old Apr 6, 2006 | 12:41 AM
r33's Avatar
r33
i dont know if my stock oil pressure gauge is off or what. here's the readin
under operation: 60
idle: between 30 and 60 (45 i guess) and idle speed is 800
car is a 88 t2 all stock.
Is that normal??
Old Apr 6, 2006 | 12:59 AM
Sgt. Pepper's Avatar
My stock guage shows around 20PSI at idle and 60PSI when driving. I heard that the stock guages suck. I'm also idling at 650, maybe that's why my idle PSI is so low?
Old Apr 6, 2006 | 01:20 AM
Brody8877's Avatar
#FakeCarEnthusaist
same here as pressure but i idle around 700 - 800
Old Apr 6, 2006 | 01:21 AM
RotaryEvolution's Avatar
Sharp Claws
high oil pressure is mainly only bad on turboed engines because it can be forced past the turbo seals.
the majority rules though, 30-45 at idle and 60ish when cruising, it should only read higher than 60 if there has been an oil regulator modification made. i prefer not to run over 60psi on turboed engines for reasons stated earlier, it can be done but the turbo would require it's own regulator or regulatory device.
Old Apr 6, 2006 | 12:34 PM
r33's Avatar
r33
as you said high oil pressure is bad for turbo car and my idle oil pressure is right on the border line so should i adjust it back to let say below 45?
Old Apr 6, 2006 | 06:31 PM
r33's Avatar
r33
Old Apr 10, 2006 | 02:11 PM
slpin's Avatar
7th Heaven
or your 18 years old gauge might just be off....
what makes you think YOU could adjust it?
Old Apr 10, 2006 | 02:19 PM
J-Rat's Avatar
Alcohol Fueled!
Well, theoretically you can adjust pressure down by lowering the viscosity of the oil used.
According to the FSM, standard pressure is about 64-78 PSI on a 3k free rev.
Rat
Old Apr 10, 2006 | 02:27 PM
slpin's Avatar
7th Heaven
Rat
you are correct... but lowering the viscosity would only affect the lower rpm...
once the rpm gets high enough, it will still be where the OPR is set at...
Sideways7's Avatar
My car can about 0-10 at idle, 40-50 when driving. I think it had a front cover oil seal leak though.
Old Apr 12, 2006 | 11:45 PM
Jerek10's Avatar
same here. idling itll be at 30... and on the stock gauge it'll eventually drop to 0. while still idling. and jump to around to 30-45 with some throttle.
Old Apr 12, 2006 | 11:57 PM
unW7WZ's Avatar
Rat
I must be running the wrong oil then. 20W50 Royal purple it will be from now on.... Mine stays right around 50 at idle.. At WOT max maybe 70... Although a turbo rebuild is immenent.... I found oil in the intake duct....Can the cold side leak oil? I am assuming so.... Man i just need to strip this engine and start from bare block......
Old Apr 13, 2006 | 02:17 AM
slpin's Avatar
7th Heaven
its because the tid connects to the crankcase
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
