(IGNITION) main pully and timing
Old Jan 12, 2006 | 05:47 PM
3rd and final 7's Avatar
wheres the water goin?
i changed my water pump today on my 84 SE ( the old was a cheap design) and i pulled my main pully off without thinknig about it and im not too sure i put it back on correctly. i pulled it and took a look at it to find the timing marks and i was curseing myself when i didnt mark it 4 i pulled it off. heres my question how do i know if i put it back on right i put it back to how i thought i pulled it off, and then i rotated the pully 90 degrees and it still went on find so i put it back on the way that i thought that i pulled it off. how do i do this right bc i would like to play alil with my timing in the near future. can you guys help
thanks
charles
Old Jan 12, 2006 | 05:52 PM
Dan_s_young's Avatar
Turbo widebody FB
I have had this exact problem before, but on a 12a... I think the solution may be the same, take the flywheel inspection plate off (just above the exhaust, on the edge of the tranny bellhousing), and when the skinny part of the flywheel lines up with the inspection plate you put the pulley on so that the timing marks line up with the indicator pin on the front of the motor.
Old Jan 12, 2006 | 06:16 PM
Siraniko's Avatar
RX for fun
Its almost time for me to go home. so its postwhoring time.
Old Jan 13, 2006 | 11:05 AM
trochoid's Avatar
Old Fart Young at Heart
Nice job Wacky. You saved 2988 words with your post, and explained better than most any one of us could.
Old Jan 13, 2006 | 10:31 PM
Whanrow's Avatar
Certified Old Fart
From: Inkerman, On, South of Ottawa, the 2nd coldest Capital in the World
Boy is that ever good. I've read about a dozen different threads that would add up to a small novel, and none explained it as good as those pictures!
Old Jan 14, 2006 | 01:00 AM
Siraniko's Avatar
RX for fun
Im just glad to be able to give something back to the community. BTW,keep in mind that the above pix are for 12-A motor. Remember, once you have the flywheel lined up with the rear housing, one of the pulley bolts is your 0 as long as it is or near the 12 oclock position.
Old Jan 14, 2006 | 11:05 AM
so just take the cover off where the eng and trans meet turn the pully till i see that divit in the flywheel and at that point i should postion the pully the leading mark is at 12 o'clock and im good to go?
Old Jan 15, 2006 | 01:29 AM
wecycle's Avatar
automatic?
Is there a similar mark on the flex plate or torque converter on the automatic cars.
Old Jan 15, 2006 | 10:02 AM
Siraniko's Avatar
RX for fun
not on torque plate but on the rear counterweight which is kinda hard to see when installed. look at the e-shaft's key in the pix below. it will keep ya the idea. if not, let me know and I will look at the flex plate in my pile of junks
Old Mar 12, 2006 | 10:17 AM
legokcen's Avatar
I had this same exact question and found this through the search function! Thanks for the answer.
Take it from me folks, I'm living proof.... Searching Works!
Old Mar 12, 2006 | 11:42 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Finally! Pics to illustrate what has been posted about on this board for years!
Excellent job!
Old Mar 12, 2006 | 11:48 AM
Wankelguy's Avatar
Wait a minute, are you talking about the little balancing hole when you say "divot"?
'Cause you know those balancing holes can be located in different places on different flywheels, depending on the individual flywheel and where the holes need to be drilled to balance it. So you can't use them as a TDC reference.
Old Mar 13, 2006 | 12:56 AM
wecycle's Avatar
Front pully
Anyone got an extra front pully laying around they want to send to me?
Dennis
Old Apr 3, 2006 | 02:59 PM
legokcen's Avatar
I'm sure I do. Let me check in my random parts bin. I've got 3 motors I've torn down lately, I'm sure there is one in there from one of them.
Old Apr 3, 2006 | 05:45 PM
vipernicus42's Avatar
Rotoholic Moderookie
Nope, he's talking about the part where the flywheel loses that "lip"
Archived! (wacky now you can't say I don't archive your stuff when I see it!)
Jon
C. Ludwig
Jan 30, 2019 06:31 AM
Jun 26, 2016 10:21 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
