Which plugs for 400hp single turbo?
Old Mar 25, 2006 | 09:35 PM
GOTBANNED?'s Avatar
Boost Addict
I drive my car alot in the summer and was wondering what sparckplugs some of of you guys are running on your single turbo..need some suggestions.
Old Mar 25, 2006 | 10:42 PM
ROTARYFDTT's Avatar
Ding King
If you’re at 400HP with your single turbo set up I'd stick with 9s all around. That's what I was running on the stock twins at ~350wheel (~400HP) along with HKS twin power. I didn't have any issues with that combination, and I'll be running the same set-up with the 62-1 unless I have some issues. I haven't read anything definitive recommending otherwise at that power level.
Old Mar 25, 2006 | 11:27 PM
I run a jacobs rotary pro pak with an FC leading coil, and typically run 9s for anything under about 1 bar. For higher boost, I run NGK or Greddy Race plugs in 10.5 or 11 in the leading holes.
Old Mar 26, 2006 | 12:07 AM
GOTBANNED?'s Avatar
Boost Addict
well i;m really shooting for is 400hp at most out of my turbo 60-1 dual ball bearing at like 18 psi max. I road race the car and drive daily aswell
Old Mar 26, 2006 | 07:48 AM
then I recommend my setup, jacobs amp, fc coil, stock plug wires, and try 9s and see how they work out.
Old Mar 26, 2006 | 09:00 AM
GOTBANNED?'s Avatar
Boost Addict
Thanks alot man, i think i will
Old Mar 26, 2006 | 09:40 AM
Jason's Avatar
The one
Twin Power or XS Power Pack and be done with it. Both are good for 18psi.
Old Mar 26, 2006 | 12:02 PM
BDC's Avatar
BDC
BDC Motorsports
9's all around, if not 10.5's.
B
Old Mar 26, 2006 | 10:54 PM
Carl Byck's Avatar
Mad Man
With a good tune you can run some colder plugs, and be alot safer IMHO. I run 11.5s, but I am going to give the Denso 11 range Iridiums a shot. I am @ 500rw@22psi. Brian, what is the downside of the race plugs besides cost? I am seriously hoping to get more miles out of the Iridiums, but we shall see.
Old Mar 27, 2006 | 08:29 AM
pistonsuk's Avatar
Can you street drive these 11.5's without fouling? If not what is the coldest plug that can be run on a street driven car and not foul?
What is the least expensive plug that can be street driven? Where do you get them?
Justin
Old Mar 27, 2006 | 03:01 PM
Poweraxel's Avatar
10.5 or 11's minimum on high boost/big power
Old Mar 27, 2006 | 05:26 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I have been running 11.5's with no fouling on the street with pumpgas/premix at 20 psi.
I bought a box of each heat range , Check the for sale section , I am selling off my extra's...
Old Apr 1, 2006 | 11:39 AM
Jesuscookies's Avatar
I can haz rotary?
I ran the NGK BR10EIX's and a twin power. No problems whatsoever. The 11.5's may be too much for your application.
sherff
Feb 24, 2019 12:09 PM
