Megasquirt lean deccel
Old Mar 22, 2006 | 01:24 PM
West-se's Avatar
bcrotary.com
lean deccel
I'm going through my logs today and notice my deccel is very lean 17:1 what can I do to fix this ? My VE is showing 43 wich i'd think would be adequate for low MAP and deccel...
RPM: 30
TPS:0
MAP: 33
VE: 43
PW: 2.5
DC: 12.5
PW2: 0
DC2: 0
Old Mar 22, 2006 | 02:54 PM
I always thout that lean conditions under decel were fine. In fact, most people cut fuel almost totally if i remember corectly.
Old Mar 22, 2006 | 03:13 PM
Rex4Life's Avatar
RX-7 Alumni
Yep, I let mine run lean on decel. Mostly using the map and about 10% fuel cut.
Old Mar 22, 2006 | 04:58 PM
muythaibxr's Avatar
MegaSquirt Mod
I run overrun fuel cut... and cut fuel completely on long decels.
Old Mar 28, 2006 | 04:00 AM
coldfire's Avatar
ERTW
what is overrun fuel cut?
also, i just have a thought that is kind of related, i wonder if fuel should be completely cut for long periods of time for engines that are running on premix? lubrication might become an issue after a long period of fuel cut...
in any case being very lean is fine when you are at 0% throttle decel.
Old Mar 28, 2006 | 06:12 AM
muythaibxr's Avatar
MegaSquirt Mod
overrun fuel cut is just fuel cut when you let off the throttle completely.
The jury is out on the fuel cut while premixing issue. I've heard that it does matter, and I've heard that it doesn't.
Old Mar 28, 2006 | 11:50 AM
Rex4Life's Avatar
RX-7 Alumni
I premix and don't cut the fuel completely. It's pretty easy to keep a little fuel going in and still lube the rotors--that's why at real low kpa's my fuel table has real low ve's.
Old Mar 28, 2006 | 01:55 PM
pmrobert's Avatar
I premix and do the same - 25K+ miles and no problems yet, excellent compression last time I checked!
-Mike
Old Mar 28, 2006 | 08:04 PM
coldfire's Avatar
ERTW
lubrication issues may present themselves as long-term problems, not short term...
in any case, it seems that putting a small amount of fuel on decel if you premix is a good idea, just to be safe, as long as it runs smooth under that condition.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
WyomingTII
Sep 28, 2015 10:32 AM
