Haltech my TPS is broken...replacement part #??
Old Mar 17, 2006 | 06:29 PM
yusoslo's Avatar
I have injector envy!
well it seems when I got my haltech the TPS was broken. IT rotates freely in any direction and puts out irratic signals to the computer.
now I have a S5 TPS that I could use but my motor is a S4 and supposedly it wont bolt up.
is there a TPS that i can get at a local parts store that will still work?
I dont want to have to wait on a Haltech one that is overpriced, but if thats what I have to do, then I will.
Old Mar 18, 2006 | 08:50 AM
yusoslo's Avatar
anyone know before i buy this thing?
Old Mar 18, 2006 | 10:58 AM
tims's Avatar
sorry, but I don't know the Haltech P/N. I have used two other 3 wire tps's with good results. The one that is on my car now is from some small ford engine. basicly any of the variable resistor type tps will work. A little search through the ignition catalog at a very friendly auto parts store will get you something that will work. or buy one from one of the Haltech dealers.
Old Mar 18, 2006 | 02:45 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
You can use any 0-5v TPS you can find and fit onto your throttle, doesnt matter, as long as the range is that it will work with the haltech when properly calibrated.
Old Mar 19, 2006 | 02:19 PM
yusoslo's Avatar
thanks I will look into that.
so if I am getting so signal from the tps, would that cause the car to have trouble reving? It idles fine but when I give it gas it hesitates and then revs. I obviously have to fix this first but I am assuming it has something to do with it.
Old Mar 19, 2006 | 09:21 PM
EFI Tech Wannabe
Yes, because its reading on map sensor alone, and the tps plays a part in the aceleration enrichments as well as load sensing.
Old Mar 20, 2006 | 08:22 AM
yusoslo's Avatar
well I have a whole S5 throttle body assembly and TPS that I can bolt on for 10 bucks. I'm still gonna look at the parts store for a sensor but if its more than 30-40 bucks I will just use the S5 TB and do the TB mod all over again
Old Mar 20, 2006 | 11:28 AM
EFI Tech Wannabe
I would just bolt up the S5 throttle and be done with it, no worries there on using that, its been done to death.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
incubuseva
14
Sep 3, 2015 12:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
