sunroof clogged
Old Feb 7, 2002 | 09:13 AM
vmb
sunroof clogged
ive been looking for the drain on my sunrooof but i cant find it .....if anyone has a pic of them i would appreciate it ............if not where are they located .......is it near the rails ?do you have to remove the rails to gain access to them ? what size are they? how many holes ?
thanks
Old Feb 7, 2002 | 09:23 AM
Tjive999's Avatar
i wasn't aware that there are drains on the sunroof.
Old Feb 7, 2002 | 10:15 AM
FEDREX's Avatar
"Just Looking".......
I don't think they have a drain - soak it up and replace the seal.
vmb
YEP ! thats what i heard ......but i cant find them.....need hair around the hole !
Old Feb 7, 2002 | 11:02 AM
Cwaters's Avatar
Just Messing About
There are drain tubes in each corner. The front two run down the A pillars and down throught he floor and the rears drain into the hatch rail drains (IIRC).
If they are clogged, you can try fishing a stiff wire like a hanger or something down the tubes.
Cory
Old Feb 7, 2002 | 11:32 AM
vmb
everyone keeps telling me run a wire thru them.......THE PROBLEM IS THAT I CANT FIND THE HOLE!!!!!!!!
can ANYONE be more specific as to where the drain holes are !!!!!!
Old Feb 7, 2002 | 12:15 PM
Cwaters's Avatar
Just Messing About
They are in each corner on the outside of the tracks. It might be esier to work with if you taket he actuall roof panel off..you'd get a better view at least. The inside headliner just pops off and there's a few nuts that hold the panel on.
Old Feb 7, 2002 | 12:31 PM
ianbell's Avatar
They are a moulded tube at each extreme c orner of the frame - DO NOT poke wire down them - the rubber hoses just slide over the metal tubes and the front ones are at least three feet long. Shoving wire down you are likely to either tear the rubber or push it off the drain tube - use compressed air.
Ian
Old Feb 7, 2002 | 12:32 PM
vmb
THANKS
Old Feb 23, 2002 | 01:32 PM
vmb2's Avatar
i havent founf the holes yet and its rainging like **** over here !!!!
Old Feb 23, 2002 | 01:37 PM
RETed's Avatar
Oops, wrong post I replied to...
I REALLY need my sleep now!
-Ted
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
