3rd gen tranny in T2?
Old Feb 6, 2002 | 04:14 PM
Question 3rd gen tranny in T2?
I know the the T2 tranny is a good piece but the time it takes to shift is forever compared to a say... Integra. So would a 3rd gen tranny fit in a T2?
Just pondering while I was driving in my pos 91 Mirage.
Old Feb 6, 2002 | 04:23 PM
vmb
sorry to bust your bubble ....it wont fit .......different trans mounts and driveshaft
Old Feb 6, 2002 | 04:27 PM
Node's Avatar
short throw shifter and a heavy shif **** might help your problems.
Old Feb 6, 2002 | 04:28 PM
cymfc3s's Avatar
I Raise Chickens
the 3rd gen shifts the same as a 2nd gen. They are virtually identical internal, excect the dual cone syncros are different on the 3rd gens.
Old Feb 6, 2002 | 04:47 PM
Damn! I've never driven or been lucky enough to ride in a 3rd gen.
but it was worth the thought.
Old Feb 6, 2002 | 05:30 PM
Poindexter10thae's Avatar
AKA Poindexter
Something to think of, the shifter is operated by the driver, it is as fast as you want it to be.
Old Feb 6, 2002 | 05:38 PM
jmseven's Avatar
Asset is Wealth
I have read articles on FD w/ FC tranny's....FC's are stronger.
Old Feb 6, 2002 | 05:46 PM
hondah8er's Avatar
mazdaspeed 3 coming soon
the turbo 2 tranny is the best Rex tranny period...and the strongest
Old Feb 6, 2002 | 05:54 PM
Node's Avatar
They're the same except for 5th gear I thought. Well mounts too.
The 3rd gen has a heavy shifter. I don't know if the 2nd gen has a heavy one or not. But like I said, that could make a big difference.
Plus a short shifter, it could practically shift itself, or make it much easier.
Maybe put something heavy on your shifter to see if you like the feel.
Old Feb 6, 2002 | 06:52 PM
RETed's Avatar
It won't fit - adding to what everyone else has said, the input shaft is about 1/2" shorter on the FD trans.
-Ted
Old Feb 6, 2002 | 06:54 PM
Felix Wankel's Avatar
Super Newbie
Not to mention the different size and type clutch...
Old Feb 6, 2002 | 08:58 PM
mazdaspeed7's Avatar
mad scientist
To clarify a little on the clutch, the FD uses a pull-type pressure plate, while the FC uses a push type. The pull type is INFERIOR as higher power levels compared to the puch type. So the FC tranny is better for high hp applications, and everything else than the FD tranny. The only thing the FD tranny has going for it is the Powerplant frame, which you cant use on anything but an FD anyways(possibly a Miata).
Old Feb 6, 2002 | 09:07 PM
Angel Guard Racing Team's Avatar
We had a 3rd gen tranny on 2nd gen engine. All you need to do is move the mount and have the drive shaft fitted. The 3rd gen is better plus the clutch system is not the same as 1st and 2nd gen so it would be a nice swap.
Old Feb 6, 2002 | 09:27 PM
cymfc3s's Avatar
I Raise Chickens
You can change the input shaft, convert the clutch over, blah. Big waste of effort. The T2 tranny is just as good if not better.
Rotospectre
Sep 13, 2015 11:22 PM
