What does everyone mean by when.....
Old Feb 6, 2002 | 11:55 AM
NVMYRX7's Avatar
i heard of someone saying they rewired their FD fuel pump!!
Could i do this to my 87 N/A???
What happens when i do this???
Old Feb 6, 2002 | 12:02 PM
Samps's Avatar
There is no reason to ever rewire a NA fuel pump. If anything get a TII pump; but even that is only for extreme cases (nitrous).
Old Feb 6, 2002 | 12:03 PM
cymfc3s's Avatar
I Raise Chickens
Older mazda wiring, including the ones that run to the fuel pump is too small and poor to give the fuel pump a full 12-14v to the pump. If you put a volt meter to the fuel pump and drive it at WOT, you can check to see how much voltage your getting. By running an bigger copper wire right from the battery to the pump you can give the pump extra juice and will increase its output.
On my 323, i ran a fused (30amp) wire from the battery to a 30 amp bosch relay. I used the factory fuel pump wiring as the trigger. I also upgraded the ground wire as well.
Old Feb 6, 2002 | 12:06 PM
NVMYRX7's Avatar
and that WORKED maybe that 's what i need to fix my hesiatation????????????????? what does everyone think?
Old Feb 6, 2002 | 12:09 PM
Samps's Avatar
An NA will almost never need to see the maximum output from its stock pump, unless you have some serious mods. I think your problem is elseware.
Old Feb 6, 2002 | 12:11 PM
NVMYRX7's Avatar
Question dude just wondering
what is "SAMPS"???????????????i have to know!!!!
Old Feb 6, 2002 | 12:13 PM
Samps's Avatar
the first five letters of my last name "Sampson"
94MazdaRX7
Nov 13, 2005 01:18 AM
