Has it been 6 months since the last weedwhacker/forced induction thread?
Old Feb 6, 2002 | 01:30 AM
rxse7en's Avatar
Nothing to see here.
Haven't seen the "HOMEMADE TURBO FROM AN ELECTRIC WEEDWHACKER!" topic in a long time. I guess nobody tried it. I liked the idea of using a 12v rechargeable weedwhacker blower that was RPM activated. Probably would have been good for 1 or 2 psi at the top end.
I'm gonna go look online and see how far 12v weedwhackers have evolved.
RXSE7EN
Old Feb 6, 2002 | 07:14 AM
Josepi's Avatar
Despise Enmity
As I recall, it was put off when discovered that even though it flows a high rate of speed, its not flowing enough air at that said speed.
Old Feb 6, 2002 | 11:38 AM
rx7_turbo2's Avatar
Professor D.P
I think that thread ranked as the most retarted idea of all time.
Old Feb 6, 2002 | 11:42 AM
SpeedRacer's Avatar
Formula Mazda Driver
Consider that notion second-ed. Its all about the compression people, not just how fast air is flowing.
Old Feb 6, 2002 | 11:57 AM
Samps's Avatar
What if you just hooked up your exhaust manifold right up to you intake manifold? Think about how much power you would make.
Old Feb 6, 2002 | 12:08 PM
rx7_turbo2's Avatar
Professor D.P
"How about I yank my wastegate hose to see what the max boost I can create is. I have no fuel mods, or any idea what I'm doing under the hood but...."
Next Day
"My car wont start, any ideas?"
I've seen those kind of posts every once and awhile.
Old Feb 6, 2002 | 12:11 PM
Samps's Avatar
What's the ATF trick?????
Old Feb 6, 2002 | 01:05 PM
rx7_turbo2's Avatar
Professor D.P
"People who put V8's in RX-7's are stupid"
Old Feb 6, 2002 | 02:18 PM
mazdaspeed7's Avatar
mad scientist
I seriously had someone try to tell me that. I was trying my hardest not to laugh at him or call him a moron.
Old Feb 6, 2002 | 02:19 PM
Felix Wankel's Avatar
Super Newbie
Old Feb 6, 2002 | 02:37 PM
SpeedRacer's Avatar
Who can tell me about the midget actuated 6-ports? I've used the search function but can't find it.
Old Feb 6, 2002 | 04:04 PM
Boosting_FC's Avatar
I know this may raise heated discussions...
But how about the idea of using an electric blower to supply air to the intercooler (or even the radiator for those FMIC guys)? What does everyone think? Will it benefit? Just a thought...
Jay
Old Feb 6, 2002 | 06:18 PM
7Rebel's Avatar
How do I turbo my n/a?
Old Feb 6, 2002 | 07:01 PM
JarrardB's Avatar
Jay
yes you would benifit....
just put a nice big 16 inch thermo fan on the front/back of your intercooler and voila.....
this is especially handy for those who have an intercooler which blocks airflow to the radiator....
using a "suck through" fan on the back of the cooler and one on the radiator would get quite good airflow over the radiator and keep the engine nice and cool....
i doubt youd see much performance gains though.
Old Feb 6, 2002 | 09:32 PM
V8RX7com's Avatar
Old Feb 6, 2002 | 09:43 PM
Gene's Avatar
10 lb. boost, 5lb. bag
putting a fan on the intercooler is a good idea, especially when you spend a lot of time in low speeds where heat soak is probable (especially with the shitty stock mount IC)
Old Feb 6, 2002 | 09:51 PM
von's Avatar
von
Im seriouse with this one... Someone can correct me if im wrong but, How about finding a small electric water pump and use a oil cooler rad for r12 and have cool air blow in your custom cold air box. wouldnt this work for someone who has time and money on thier hands. For N/As. I hope this thought doesent come up in the stupidest ideas thread somday.
Old Feb 6, 2002 | 11:29 PM
JarrardB's Avatar
You could just use a big (10cm x 10cm) 12V electric fan (or 2) and mount them strategically so as to get lots of airflow into your box. That would work but I don't know how effective it would be...
Old Feb 7, 2002 | 02:23 PM
von's Avatar
von
Actually I was thinking of having the old blower motor off the ac rerowted into the box. How about that.
DerpyToast
14
Nov 23, 2024 05:19 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
SCinfidel
Sep 8, 2015 05:36 PM
