What did Mazda do between the '88 to '89 model years?
Old Feb 5, 2002 | 04:35 PM
Barwick's Avatar
SCCA Rookie
I've seen that the early FCs and the later FCs have like a 200+ lb weight difference between them. What DID Mazda do between these cars to make the later ones weigh so much more?
And another thing, as for the N/A vs Turbo differences, I know the engine, tranny, and hood are different, as well as ECU and related equipment (exhaust too?), but what all else are the differences between the N/A RX-7's and the TurboII's? Probably larger wheels/tires, rear end, brakes? (4-piston maybe? I dunno).. What all are those differences between the N/A and Turbo RX-7's also?
And don't give me crap about "use the search function" cause I looked and couldn't find much of anything useful that answered these questions.
Old Feb 5, 2002 | 04:49 PM
cymfc3s's Avatar
I Raise Chickens
use the search feature. =P Series 5 have a completely different motor, ecu and harness. Its OBD1. The ecu and harness have more in common with the 3rd gen then they do with the 87-88. A few updates in the interior and exterior. The suspensions are almost the same. 86-88's have a different lower a-arm with a replaceable ball joint, different sway bar end links.
Old Feb 5, 2002 | 08:18 PM
tmak26b's Avatar
Where did the 200lbs come from? Let see
Automatic Seatbelt, bigger gas tank, steel hood, jack, more sound deadening material (you get less leg room in a 89+), the dash is heavier and many othjer stupid little things
Old Feb 5, 2002 | 09:48 PM
Roy James's Avatar
My cars louder than yours
so is the 89+ cars just built better and a little heavier duty? .. or just heavier? i have a damn gay *** 88... gay gay gay gay gay gay. no turbo GTU.. and... the low hp years... doh doh doh doh doh!
Old Feb 5, 2002 | 10:47 PM
https://www.rx7club.com/forum/showth...threadid=48244
lists many differences between the years and na/turbo models
https://www.rx7club.com/forum/showth...threadid=46982
more crap on driveshaft/ gearbox/ suspension differences
https://www.rx7club.com/forum/showth...threadid=45407
suspension
https://www.rx7club.com/forum/showth...threadid=31809
brakes difference in NA
https://www.rx7club.com/forum/showth...threadid=39517
more info
https://www.rx7club.com/forum/showth...threadid=14753
gas tank difference
https://www.rx7club.com/forum/showth...threadid=38793
if u wanna get into compression..
https://www.rx7club.com/forum/showth...threadid=25205
difference between NA and TII
https://www.rx7club.com/forum/showth...threadid=16938
something
https://www.rx7club.com/forum/showth...threadid=17421
this post answered
what were you saying about the search function again?
Old Feb 5, 2002 | 11:03 PM
Barwick's Avatar
SCCA Rookie
yeah, I was saying the search didn't return much useful.. maybe I just don't know what to search for, I tried about 6 or 7 different searches
but thanks for the info
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
