Fuel Cut on an N/A?
Old Feb 5, 2002 | 12:11 AM
Drakk0r's Avatar
Fuel Cut on an N/A?
Does the N/A ECU have a fuel cut like the TII if you go over 8.9psi manifold pressure? Just wondering, cause I dont wanna find out the hard way when I finish my little turbo project. Fuel cut on a turbo N/A running over 8.9 psi = bad.
Old Feb 5, 2002 | 12:15 AM
Agent_D's Avatar
rawr
8.9 psi on an n/a engine = bad anyways unless you got an S-AFC or some other kind of fuel controller
if you dont have a fuel controller dont run over 6 psi of boost on an n/a engine, dont know about the fuel cut off though, i just know it has a fuel cut off 600rpm over the redline reading
Old Feb 5, 2002 | 01:52 PM
mazdaspeed7's Avatar
mad scientist
Yes they have fuel cut, but as far as I know, its JUST rpm-based. I doubt there is a boost related fuel cut on n/a ECU's.
Old Feb 5, 2002 | 02:35 PM
tmak26b's Avatar
My 90 gxl coughs at 8800, then keeps going
Old Feb 5, 2002 | 02:51 PM
Agent_D's Avatar
rawr
gotta love broken rev limiters tmak all of the 7's ive had had ones that work, so no going over 7600rpm for me
Old Feb 5, 2002 | 04:43 PM
mad scientist
You suck. My car is still pulling at 8800, and the rev limiter stops all the fun.
Old Feb 5, 2002 | 05:18 PM
HAILERS's Avatar
HAILERS
I hit that once and thought I broke the engine.
Old Feb 5, 2002 | 06:16 PM
Drakk0r's Avatar
I plan on running 8-12 psi. Of course I'll have the fuel system to support it, the S-AFC to tune it, the timing retarded, and running 93 octane + octane boost in every tank. And I plan on running 4-5 psi when I first get it running, and gradually tuning it for more and more as I get the tuning right..
Old Feb 5, 2002 | 08:16 PM
tmak26b's Avatar
I have the car dynoed and tried up to 9000 RPM, on a stock car, anything about 7K RPM is useless
alphawolff
Nov 17, 2015 05:57 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
