Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
sr20 or Kat in 85 se
Old Feb 16, 2006 | 03:23 PM
Rotary85se's Avatar
Has anyone done an sr or ka swap in an fb? Can you give a sort of parts list and procedures?
Old Feb 16, 2006 | 11:38 PM
Nihilanthic's Avatar
moon ******
Short answer is no, and you probably couldnt do it.
Long answer is youd have to fabricate engine mounts and a transmission crossmember for whatever transmission youll use with those engines, unless you make a custom adaptor plate to mount it to the mazda tranny, and get a new driveshaft cut.
I HAVE seen a ford 2.3 turbo put into an FB before, www.boostbros.com
Old Feb 17, 2006 | 11:22 AM
Rotary85se's Avatar
the motor mounts and crossmembers are no problem, would the sr or ka even fit in an fb? would it fit between the shock towers? Would i have firewall issues?
Old Feb 17, 2006 | 04:33 PM
moon ******
Yes it will fit. You can box the firewall if you really want to, but therse no need.
v8s will fit in there, dont worry so badly about two 4bangers :P
Old Feb 18, 2006 | 08:28 PM
Rotary85se's Avatar
does anyone know of any rotary mechanics in NC?
Old Feb 19, 2006 | 03:51 PM
rotor vs. piston's Avatar
Function > Form
I used to be in NC as a "rotary" mechanic or the one the locals would call. Anyway too, I'm also planning a SR20det swap into my now SBC V8 FB. I don't have the engine yet and have got no diminsions on the SR, so my only concern is te hight at the front of the cam cover... I don't want a scoop of any sort. I'm selling all of my V8 stuff, and then will pick up a SR and begin the chaos.
Old Feb 19, 2006 | 04:20 PM
21K95RX7's Avatar
go to ga240sx.com look up driftjunke he runs a shop in georgia WWW.E-EMOTORSPORTS.COM he specializes in sr and Rb swaps tell him redrex7 sent you
ProjectMidnight
Oct 31, 2005 04:00 AM
1Rx72nv
11
Aug 10, 2004 11:48 AM
gugge
Jul 12, 2004 10:23 AM
skunks
Sep 19, 2003 12:42 AM
