Power steering goes stiff
Old Feb 4, 2002 | 02:22 PM
nopistons's Avatar
Occassionally, the steering on my '88 SE will get a lot stiffer than usual, and then it returns to normal. Doesn't happen often, and doesn't last long when it does. Fluid is up to the mark, and the belt is new and tightened properly. Any ideas?
Thanks in advance.
Old Feb 4, 2002 | 02:23 PM
jmseven's Avatar
Asset is Wealth
Your pump is malfunctioning.....did you use the right fluids?
Old Feb 4, 2002 | 02:45 PM
SureShot's Avatar
Seduced by the DARK SIDE
That pump is speed sensitive. The ECU may (sometimes) be telling the pump you'r going faster than you actually are.
Old Feb 4, 2002 | 02:50 PM
j9fd3s's Avatar
Community Builder
the 86-88 has a variable assist system. it is computer controlled, and they seem to get inconsistant. it is either the computer box under the left of the dash or the pump, or the connection between them. if you disconnect the computer it will default to 50% stiff
mike
Old Feb 4, 2002 | 02:57 PM
jmseven's Avatar
Asset is Wealth
Ahh yes....computer. Duhhh
LMBTG
Sep 2, 2015 07:01 PM
rotor_veux
Aug 31, 2015 07:49 PM
c0rpse
Aug 25, 2015 11:50 PM
