Cold Idle Problem - No AWS
Old Feb 15, 2006 | 10:35 AM
topaz's Avatar
Greek Geek
Hello guys. A little help please.
After a rebuild, my, stock FC3C S5 doesnt idle when cold.
The situation:
The car is cold: I turn the switch, The motor starts, vroummm, no 3000rpm, and almost instantly drops revs, and shuts down (dies).
If I press a little the gas pedal, turn the ignition, the car starts, I "help" it idle around 1200rpm about 1-3 minutes, and then idles fine.
WHEN WARM, the engine starts NORMAL, and idles NORMAL! At the road, the car pulls perfect.
I think a AWS problem, cause before the rebuild I had the "3000rpm jump" and high idle till the motor gets warm.
Now I dont have the AWS. And the motor shuts down when cold...
I know its something little that breaks my b@lls, so plz, a little expert help?
THANKS!
Old Feb 15, 2006 | 10:53 AM
deadRX7Conv's Avatar
Opinions are like........
Sounds normal to me. What did you expect from AWS removal?
Old Feb 15, 2006 | 11:03 AM
SureShot's Avatar
Seduced by the DARK SIDE
Do you still have the thermo-wax with its fast idle cam & coolant circuit?
Old Feb 15, 2006 | 11:41 AM
topaz's Avatar
Greek Geek
Eh... i didnt remove anything. SureShot I have the t wax but I need more info with the rest.
Old Feb 15, 2006 | 12:07 PM
SureShot's Avatar
There is a cold start fast idle cam on the TB.
It is advanced by a thermo-wax device.
A 3/8" coolant circuit heats the thermo-wax, which pushes back the fast idle cam after warm up.
In the FSM "fuel & emissions" section page F1-36 shows the adjustment procedure.
Click on the link in my sig & navigate to that PDF file.
You may download & print what you need.
Old Feb 15, 2006 | 12:37 PM
topaz's Avatar
Greek Geek
I will check it out!
Thank you very much!
DerpyToast
14
Nov 23, 2024 05:19 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
sherff
Sep 12, 2015 12:22 PM
83revival
Sep 3, 2015 10:42 PM
rx7shirley
Sep 2, 2015 02:11 PM
