88 engine 90 vert
Old Feb 15, 2006 | 07:39 AM
The Milo's Avatar
88 engine 90 vert
My 90 convertible’s engine is now a door stop. I have run across 88 and wanted to know if the engine in the 88 would go into the 90, or would the engine and transmission have to go into the 90?
Old Feb 15, 2006 | 10:26 AM
Juiceh's Avatar
Saiga-12 Power!
Yes, but it requires some modifications. I had an 88 engine in my 91 vert for a while. Until I turbo swapped the bitch. Check the FAQs I think all the info you need to know about s4 engines in an s5 will be in there.
Old Feb 15, 2006 | 12:28 PM
The Milo's Avatar
I check the FAQ and the swap from non turbo to turbo info is there. This is a swap from an 88 engine to a 90 vert. Which I did not see. What mods would have to be done?
Old Feb 15, 2006 | 02:17 PM
Parastie's Avatar
Mountain Rotary Mod
Go here:
http://www.rotaryresurrection.com/ro...ries4swap.html
Old Feb 15, 2006 | 02:30 PM
The Milo's Avatar
Thanks, that helps.
Old Feb 15, 2006 | 02:37 PM
jhammons01's Avatar
Carter 2.0
Dude, if you can get the engine out then you can rebuild it. Just rebuild your engine. It IS simple. You can do it in your back yard on a park bench and using a 5 gallon bucket.
To me, Getting the engine out was harder than rebuilding the long block..........
Old Feb 15, 2006 | 03:25 PM
The Milo's Avatar
I Got the engine out and the flywheel nut The rear rotors apex seals went, they thos rotated around the housing, which has damaged the rotor housing, the rotor, and the rear engine housing. So what I really need is the rotor, the rotor housing, and rear engine housing. Along with the rebuild kit. I found this car and the guy might give it up for less than a grand.
Which is what I would have to pay for the parts.
astrum
24
Nov 15, 2017 08:44 AM
CynicalGambit
Aug 17, 2015 10:41 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
