Prison Style Power (12a)
Old Feb 14, 2006 | 02:03 AM
snwyvern's Avatar
Out of the years I have been working on cars, and subsequently "Finding" solutions for "problems" I have yet to see a resource for that kind of engineering prowess for our RX-7s! What I'm getting at is: Has anyone got together a list of junkyard finds for forced induction that will "help out" our lowly 100kw engines? The prospect of dropping four thousand dollars on a supercharger setup... Or a couple thousand for a turn-key Turbo/EFI setup for the 12a... makes me want to cringe when I think about the times that I've used wrecked ford oil-coolers as make-shift intercoolers... or a couple of daisy chained GM 3800 Superchargers on a dodge (running off their own engine...) just to make it work!
My 12a needs love and I only have $1200 to give!... Plus it needs bushings!
Blah!
Old Feb 14, 2006 | 02:45 AM
Rx Seven's Avatar
Can You Wankel?
I dont think tere are any ungodly power adders out on the market for the 12a that you can find at your local junk yard. And from what you said above I'm sure you have some car knowlege from your previous experiences from working on pisssed-on engines before.
I am sure you can turbo your 12a using a TII turbo. Go to the junk yard or in the forsale section and start collecting the parts you need, Turbo, Intercooler, Manifold, Carb Hat etc.etc. etc. I think you should talk to FB II he has a turbo 12a and I am sure you can get it done for $1200 doing the work your self.
But I think to make the power that you want to make out of a 12a you are going to have to spend money and lots of it. But maybe you will be the one to come up with the monster we have been looking for. Just my .02. Good luck with your project
Old Feb 14, 2006 | 09:28 AM
Hades12's Avatar
Burning Oil-Grinding 3rd
How about some pics of that SC setup?
A lot of the turbo setups in this section are JY setups. But no one has really made a list of the best cars to pull turbos from.
Old Feb 14, 2006 | 09:49 AM
13btnos's Avatar
Stock S5 turbo from a TurboII RX7 and the stock Nikki carb setup for boost. http://www.rotaryshack.com/Home.asp this place can modify a stock carb to run boost. Can't get anymore simpler and cheaper than that.
Old Feb 14, 2006 | 12:43 PM
snwyvern's Avatar
See, this was supposed to be some midnight hour miracle... With a response like: "Yeah, you can just grab a turbo off a Mitsubishi Eclipse or GTO... and use the exhaust pipe backwards for the downpipe... And the manifold can come off a Yugo... As for the carb, toss that out and glue a fuel rail from a Camaro right to the intake! Or use a GM TBI!"
... But thanks for your input guys. There's an abundence of RX7s in Junk Yards here anyway
Old Feb 14, 2006 | 03:17 PM
dj55b's Avatar
Its just the crowd of people here ... people don't seem to like to mix and match too many piston with rotary stuff ... i'm with you though i'd like to see some "performance" cars like that. If I had the time to do a car like that i probably would. Really if we're only spending a few hundered bucks off our cars why not?
Old Feb 14, 2006 | 03:28 PM
no_name's Avatar
Duct-tape fixes all
The superchargers of 1991 and up Ford thunderbird SC could be used with a rotary engine if you do some jerry riging.... I may do that one my self some day. The Turbo II turbo will work easily, but you will have to fab the exhaust manifold. ( i think you can actualy buy one from racing beat or something)
Old Feb 14, 2006 | 04:04 PM
FirebirdSlayer666's Avatar
Famous Taillights
TII turbo is the way to go. It's cheap and it gives you good power. But if you're trying to get 400rwhp out of $1200 just forget it. You could easily make 200+ with simple swaps. 2nd Gen Direct Fire Ignition, loose the beehive, rats nest removal if you don't need to do emissions, etc. Even running a different oil will gain you some hp. Alot of simple stuff like that can give you hp
Old Feb 14, 2006 | 05:57 PM
1badFB's Avatar
GSSL-SE
Haha, as soon as I read about the 3800 sc's running off their own engine I said to myself Im sure with 1200, you could get all the bushings you need, aaaand a gas powered leaf blower. With a few duct taped connections youd have youself another self powered supercharger setup haha.
Old Feb 14, 2006 | 06:16 PM
jfachner72's Avatar
"1ST GENS" THE REAL RX-7!
From what i understand the lobes on the T-Bird S/C as well as the SVT Stang and the Lightning are teflon coated and they dont mix with gas real well......
Old Feb 14, 2006 | 06:42 PM
JustDoug's Avatar
Yeah! What he said!
I'm with you, snwyvern. Seems like there should be a way of "re-purposing" some of the factory performance schtuff out there. If it hasn't been done yet, doesn't that make you want to try it even more?!? You've got me thinkin' bout a trip to the local yards.....
.....when it warms up a bit. Brrrrrrrr!!!
Old Feb 14, 2006 | 07:35 PM
blwfly's Avatar
kiwi from downunder..
ic rotaryshack sells a 12a turbo motor for 1200 then u could have a whole motor for parts
Old Feb 14, 2006 | 07:42 PM
gmanuser's Avatar
wheres my calculus book?
jerry's rig
i must agrea with my freind here that jerry's big rig is the way to go, my neighbor and I have saved well over 1,000 dollars on parts for my car by this way, for example thier is some bushings a bolt and a pin that makes my right door work ehhehehe my gas tank opens via grinding the crap off stuff so i just have to hit it to open it hahahah beat that, and my rear latch you gota thump and twist, you have to start my car in first gear to start it, and very many other good things that i have fixed/ made this way hahahha good times good times.
Old Feb 14, 2006 | 08:47 PM
joker90p's Avatar
need more info im probly pickin up a 1st gen tomorrow. whats the beehive, and how do i use the direct fire from a FC cuz i have a wrecked FC sittin in my garage.
Old Feb 14, 2006 | 09:08 PM
Famous Taillights
Check in the FAQ section. You'll find everything you need to know there. If not PM me and I will inform you
Old Feb 14, 2006 | 09:25 PM
no_name's Avatar
Duct-tape fixes all
Nice work gmanuser. I have a fuel tank leak I fixed with bublegum, and I replaced some vacume hoses on my carb with fishtank tubing. I also taped the electrical conectors in my car in a way so the head lights would work. This mod saved me riupping out the combanation switch and all that jazz and rebuilding it.
Jerry rigging is teh way to go. Long as you know what you did. The best part is not the moeny you saved but the satasfaction that if somone jacks your car they are not going to go far with it....
Queppa
Nov 18, 2024 03:47 AM
LMBTG
Sep 2, 2015 07:01 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
rx7brandon
Aug 16, 2015 10:55 AM
