Video: BNR Stage 3 Dynapack results
Old 02-13-06, 09:32 PM
Arrow Video: BNR Stage 3 Dynapack results
Hey guys,
here is the video from my dyno session over the summer. Thanks to scrub (dan mcvicker) for taking the time to edit the video.
I plan to hit the dynojet when the weather gets warmer.....I have resolved some minor ignition problems and think I can better the current numbers. We'll see
http://videos.streetfire.net/Player....C-069349BD885A
Old 02-13-06, 09:37 PM
Boostless FD
r0gu3's Avatar
Just sexy Rich. Very impressive.
Old 02-14-06, 11:29 PM
Jay7 Nyc's Avatar
Nice #s Richy. This summer should be fun..
Old 02-14-06, 11:52 PM
"your turbo source"
Bryan@BNR's Avatar
Hey Rich!
Great video! The car is absolutely beautiful. Performs well, looks good, what else would you want out of a driven street car??? 421 is a good feat especially with hybrid twins. I know we can squeeze a few more HP out of them just by doing a few more things the the exhaust manifolds. I think atleast 430-440 RWHP is attainable, but the more people that get these turbos and push them, the more numbers you will see . These turbos at 17-17.5 psi will get down 420's RWHP with the right mods. Been done a few cars. Cant wait for a few sequential guys to break 400 RWHP. That I think is an ideal set up if everything works properly with all the seq stuff.
Gotta love 400 plus twins! You push the boost, you make numbers if you tune the cars properly...
Bryan@BNR
205 640 1193
www.BNRturbos.com
Old 02-15-06, 02:00 AM
21K95RX7's Avatar
i posted this on another thread but thought this would be the best area.
rich,
i was watching your dyno video, and you said that it was dyno\\\'d at 19 and 21psi i believe. now it was all the same hp and tq numbers at 17 psi right? i was just wondering if bnr\\\'s run out of breath after 17 psi or was it just your ignition setup?
Old 02-15-06, 02:01 AM
21K95RX7's Avatar
bryan feel free to chime in
josh
Old 02-15-06, 07:50 AM
rich,
Hi Josh,
that little blurb on the end was Dan's (my friend who edited the video) idea of a joke.
I did not dyno at 19 or 21 psi. The highest I dynoed was 17.5 psi, which resulted in the 421 rwhp. We stopped at that level because I was running out of fuel injector.
Bryan has told me in the past these twins will run out of breath after 19-20 or so psi.
Rich
Old 02-15-06, 11:56 AM
LUPE's Avatar
Cool video!!!
Get those dynojet numbers, they might be higher
Old 02-15-06, 12:02 PM
Ahh du ma! El Es Juan!
audiobot7's Avatar
Nice numbers.
Old 02-15-06, 01:26 PM
21K95RX7's Avatar
Originally Posted by GoodfellaFD3S
Hi Josh,
Rich
cool that thing is a beast i would love to see the 450 barrier broken with twins
Old 02-15-06, 09:04 PM
Yes its slow
Slammedblk7's Avatar
i will trade you my car.
Old 02-16-06, 01:23 PM
Robertio's Avatar
Unfortunately I can't see that happening. As far as I can work out just over 430 should be them maxed out. We got 404rwhp out of my car with the turbos out of flow (1.3bar plus a 50 shot was giving no more power than 1.15bar and no gas) - given the 0.3bar pressure drop across the intercooler (we were seeing on my car) is worth around 30rwhp. Will find out for sure when I get my monster vmic over from Chuck
Assuming I can see 430 on pump fuel I'd guess leaning it out to 12:1 on race fuel might gain an extra 10-15rwhp, but just can't see 450 being possible. Would love to be proven wrong though.
Old 02-16-06, 08:04 PM
After I was done on the dynapack, I spoke to the operator and shop owner, and he told me that consistently customers that went to a dynojet after the dynpack made ~5% more rwhp on the dynojet, which is where most people have their power measured. Granted it is theoretical, but that alone is enough to bump my results up towards 450. We shall see .
Old 02-19-06, 02:02 PM
Robertio's Avatar
Best of luck with it Rich, fingers crossed for you
Mine was done on a Dyno Dynamics setup, which is as close to a standard as we have over here. Will probably be April before I get mine back on the dyno with new downpipe and v-mount, but will be interesting to see how both cars compare when they are finally finished
Old 02-19-06, 05:44 PM
Rotary addict since 86
WanKeL FD RX-7's Avatar
great numbers, great car too ... bnr turbos seems to be very good turbos...
Max
Old 03-24-06, 09:32 AM
Doritos on a toothpick
BoostCrzy's Avatar
how are these turbos at 14-15psi??....
Old 03-24-06, 09:37 AM
I think I made 390ish rwhp at 1 bar (14.5 psi).
I am doing everything I can to get the car prepped and on the dynojet this coming weekend with a better ignition, intake and exhaust setup.....
Rich
Old 03-24-06, 12:38 PM
Robertio's Avatar
Best of luck with it Rich Bax Global have lost my vmount so it will be a while before I get the insurance money back from it, and get Chuck to make up another one, so I can play catch up
I was stuck around 360rwhp @ 14psi on my last engine, only have figs for the current one at ~16.5psi but working it back gives ~380 at 14.5psi.
Old 03-24-06, 01:46 PM
silver ghost
G's 3rd Gen's Avatar
rich.. the 421 pull was on the stock ignition?
Old 03-24-06, 02:00 PM
BoostCrzy's Avatar
Rich
wow.....thats great!!! I'm assuming these puppies are in efficiency between there and 18psi......???
i'm trying to find a good turbo (or turbos) setup that can operate at about 15-16psi and make decent numbers....i use the stock ECU with a aux injector controller for extra fuel....i would like to keep using this combo and just get more air into her at the same pressures....
Old 03-24-06, 03:40 PM
Bryan (BNR) has told me they will max out around 18 or 19 psi, I may try 20 psi on race gas to see the results. The factory turbine housings become the restriction at this boost level. I will tell you my car seems to love 15-16 psi, and my intake/water temps do not rise much even when ripping on the car repeatedly at that boost level.
Re: the stock ecu with fuel controller, not too sure if that's a good idea. what else do you have for the rest of your fuel system? I hope it's not stock.
Old 03-25-06, 09:44 AM
bow leggin'
Scrub's Avatar
Hey Rich, Nice numbers buddy. Good luck on the dyno this weekend. Also, who hosted your video? I need someone to host mine.
Old 03-25-06, 09:48 AM
Rx7 Wagon
Narfle's Avatar
Your car is my inspiration. That being said, please stop raising my bar.
Old 03-25-06, 10:15 AM
STUCK. I got SNOWNED!!!!!
Terrh's Avatar
nice numbers!
your car sounds badass at idle.
Old 03-25-06, 10:22 PM
Will u do me a kindness?
the_glass_man's Avatar
Rich was that on pump gas? Nice numbers BTW!
Quick Reply: Video: BNR Stage 3 Dynapack results
