Dash illumination
Old Feb 13, 2006 | 08:03 PM
no_name's Avatar
Duct-tape fixes all
Dash illumination
Hello all. I hate to plague you with such an amature question, but I want asurance. Today when driving, my dashboard illumination went out. When I made it to my final destination, the headlights would turn on and off, but would not go back down. This leads me to belive that the middle fusable link is burnt out. Am I correct?
I also have a more pressing issue. My choke *** fell off. How do I put it back on?
Thanks in advanced Ted.
Old Feb 13, 2006 | 08:06 PM
aussiesmg's Avatar
Thunder from downunder
If your middle fuseable link was burnt out the car wouldn't crank, no lights nothing.....sounds like the dimmer switch or the wiring under the console is bad.
Old Feb 13, 2006 | 08:09 PM
Rogue_Wulff's Avatar
Too old to act my age
Could be the fuse. Do the marker lights work? I had the exact same symptoms when the tail light fuse blew.
Old Feb 13, 2006 | 11:53 PM
REVHED's Avatar
Hunting Skylines
Yes. Check the tail/illumination fuse.
Old Feb 14, 2006 | 09:57 AM
Rotor Nut's Avatar
Project X605
I have the same problem with my 84 GSL. What it is the fuse in the fuse box is lose or blown. Check it and/or replace it.
Old Feb 14, 2006 | 01:07 PM
mbaha's Avatar
ditto "Yes. Check the tail/illumination fuse."
Old Feb 14, 2006 | 01:22 PM
Mr. Peanut's Avatar
The choke **** is held in place by a small screw on the bottom of it. It screws up into the metal choke rod. The screw probably just fell out or backed out enough that the **** came off when it was pulled. You might have to pull the rod out a little bit with a pair of vice grips (clamp onto the rod near the dash panel) in order to line the screw up with the hole. At least thats how it is on my 82 and 83.
Old Feb 14, 2006 | 03:22 PM
no_name's Avatar
Duct-tape fixes all
Thanks guys. This happend to me in the dark so I did not see what was going on. ( I had a reason to speed) Today in the morning I discovered teh screw for the choke, and in auto class I took a look at the fuse and sure enough it was the fuse. Thanks for your help guys.
Old Feb 15, 2006 | 03:48 PM
no_name's Avatar
Duct-tape fixes all
I take it back. I thought I solved the problem, but the dash illumination still does not work. I am relativly sure I am not getting ground, so I am wondering whare is the ground for teh dash illumination control?
Sorry to bring it back up thanks in advanced, Ted.
Sh00bs
Oct 1, 2015 11:57 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
