smoking rotory when cold
Old Feb 4, 2002 | 12:45 AM
My 88 gtu was fine untill some one gave me the slick idea.I was told it would condition my motor if i put auto tranny fluid in the rotors.So i did bad idea.Ya for some reason the car seem to run better now.But ever morning when i start it it smoke like a beast untill it warms up. After it warms up it doesnt smoke at all. Iam thinking the tran fluid messed up my oil seals.Anyone what could have happened?
Old Feb 4, 2002 | 12:48 AM
rico05's Avatar
WTB S5 N/A FC
Mine now does the same thing. I beleive that it brole some stuff loose around the injectors, cuz it feels kinda flooed. The ATF trick does do wonders, and most of us (90%) have done it.
Old Feb 4, 2002 | 01:21 PM
Marco's Avatar
Mine 88se does the same thing. It has done that ever since I own it. I never have to add coolant so it isn't coolant that is burned. I also don't think my car is using to much oil, i have to fill (about 500ml) some oil every 400-500 miles. btw it is white smoke!! I always thought that it was some kind of moisture that was in the exhaust due too cold temperature. I'm planning to do the ATF treatment soon but I will follow this thread for a few days first!
Marco.
Old Feb 4, 2002 | 01:25 PM
HilikusRX's Avatar
Newbie
Dude, most 2ng Gens go through a quart or two very 400-500 miles.
Old Feb 4, 2002 | 01:36 PM
Marco's Avatar
I didn't seem out of the ordinary to me. 500ml is roughly 1/8 of a gallon. I asume that a quart is quarter of a gallon?? Do you mean that it is not enough?? In that case I should reconsider adding some two-stroke oil to the fuel. I did that for while but it killed my precats. Didn't matter very much, I got rid of them and still pass emmisiontests overhere!
Marco.
Old Feb 4, 2002 | 01:37 PM
supergoat's Avatar
Eggs are like fowl cheese
I've gone almost 1200 miles since my last oil change. I checked my oil yesterday and all is fine, I didn't have to add any.
After I did the ATF trick, mine also smoked for a while when I would crank it. I changed my oil and all was well. Some of the ATF fluid CAN AND SOMETIMES WILL sneak into your oil. So always, always, always change your oil after you do the ATF trick.
Old Feb 4, 2002 | 01:47 PM
Marco's Avatar
What would happen if I don't change oil after doing the ATF treatment. I mean I just changed it 1000 miles ago. Will it just smoke or will it hurt the engine otherways. I don't think a little smoke will bother me as long as I know where it is coming from.
Marco
Old Feb 4, 2002 | 02:11 PM
supergoat's Avatar
When I did mine, I got smoke at start up and also a very lumpy idle and almost no low end power. I changed the oil and presto, a car that ran much better than before the ATF treatment.
Old Feb 4, 2002 | 03:02 PM
RX-7 Turbo II's Avatar
1987 Turbo II
my car i did not add anything to the motor but every morning when i turn it on it smokes untill it warmes up.
ls1swap
Jun 3, 2024 03:25 PM
Einheri
Oct 7, 2015 12:23 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
