GT35R T4 oil drain line
Old Feb 10, 2006 | 11:42 PM
Silver7's Avatar
I have the GT35R T4 hybrid. The problem I am having is with the oil drain line. If I setup the oil drain line so that it's coming out of the bottom side of the turbo, it hits the turbo flange. The was not a problem with my 60-1 turbo. The oil outlet on the GT35R seems to be set back a lot further towards the tubine housing. The only way to run the oil drain line is somewhere between 45 degree and horizontal. Has anyone else encountered this problem? Will the oil drain properly if it's setup sideways as opposed to straight up and down? I could take some pictures tomorrow if it will help. I am in the process of contacting Aspec about this problem but I thought I would ask here on the list in case other people are having the same problem and might already have a solution.
Josh
Old Feb 11, 2006 | 12:38 AM
Poweraxel's Avatar
email Sean at sean@a-spectuning.com
he will gladly answer any of your questions
Old Feb 11, 2006 | 01:29 PM
Silver7's Avatar
I did email him last night and he responded to me almost immediately. I was curious if anyone else has run into this issue. I also wanted to know if the oiling system can be run horizontally or near horizontally without causing damage to the turbo.
Old Feb 11, 2006 | 02:00 PM
Zero R's Avatar
Just in time to die
No you should stay around 15* or less. Shoot me a email with any other questions.
Old Feb 11, 2006 | 03:59 PM
crazyrx7's Avatar
Big Daddy!!!
I had the same problem with my gt35r with the t3 flange. I had to clock the turbo close to the 15 degrees to get the oil return line to clear. It should be pretty close with the t4 flange.
R.K.
Old Mar 26, 2006 | 12:33 AM
gonzz's Avatar
I'm having the same prob.. what did you do? I will e-mail Sean also..
Old Mar 26, 2006 | 07:32 AM
JDK's Avatar
JDK
I had the same problem as you guy's, I used some of the stock oil line flanges a 3 inch pipe and some fittings, silver soldered it all together. I had to keep the flange and the pipe coming off the turbo at about 15 degrees to clear the houseings, It is a tight fit. I have to thank my good friend Darryl for all his help and the use of his machine shop.
Old Mar 26, 2006 | 08:11 AM
Madee's Avatar
Just wanted some clarification. You purchased the A-spec GT35R kit and it was necessary to fab a different oil line to make it fit? I'm about ready to order from them and was "concerned".
Old Mar 26, 2006 | 08:23 AM
JDK's Avatar
JDK
I put the kit together myself, I bought all my parts local to me(Toronto Canada).
I don't think there is a issue with the A-spec kit. My set-up is a little over kill, I'm
using the car on the track and I really wanted to avoid problem's.
Old Mar 26, 2006 | 11:06 AM
Madee's Avatar
OK, your kit is not from A-Spec. What about Silver7, Crazyrx7 and Gonzz, do you guys have the A-Spec kit?
Old Mar 26, 2006 | 11:30 AM
Zero R's Avatar
Just in time to die
You do not need to fab anything with our kit With the 35R the Centre section is shorter which places the drain further back. This is with all the T4 housings I had made. Our oil drains get around this problem. Keep in mind that is for our positioning though. As you clock the turbo you drain may need to change in angle and position.
Old Mar 26, 2006 | 12:01 PM
gonzz's Avatar
I have the A-Spec GT35R T04 turbo.. Sean gave me some instructions to make it work. I will keep you updated how i did it..
Old Mar 26, 2006 | 12:05 PM
gonzz's Avatar
Where did you get that drain flange. I got mine from ATP turbo and looks like it might be thicker.. This is the flange i got..
Old Mar 26, 2006 | 02:44 PM
JDK's Avatar
JDK
I looked at those as well from APT but ended up taking the stock return pipes from the twin's apart and just using the flanges with fittings welded to them.
Old Mar 26, 2006 | 02:49 PM
gonzz's Avatar
Thanks, will use the info if I need it..
Old Mar 26, 2006 | 02:55 PM
Rotarded's Avatar
"Challenged" since 1993
Same here, except I just slid -10 braided over the stock flanges and clamped.
Old Mar 26, 2006 | 07:14 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
^ +1
Old Mar 26, 2006 | 09:15 PM
Silver7's Avatar
I do not have the Aspec kit. Here's what I ended up doing.
Old Mar 27, 2006 | 02:51 PM
gonzz's Avatar
I talked to a local fabrication shop today and they will make me what i need. I'll post some pics after the complete it tommorow. Thanks for all the help
Old Mar 27, 2006 | 04:37 PM
crazyrx7's Avatar
Big Daddy!!!
I have the rx7store kit. Like I said all I did was clock the turbo slightly just so that the oil drain line clears. Its around 15 degree or even less.
R.K.
Old Mar 30, 2006 | 08:03 PM
Silver7's Avatar
Do you have a picture of what you did? Are you using AN fittings with braided lines or just a nipple with rubber hose? Everyone is making it sound really easy but I had a hell of a time trying to get anything to work reliably (track use).
Old Mar 30, 2006 | 08:23 PM
gonzz's Avatar
I'll post some pics when i get it back.. just dropped it off today
Old Mar 31, 2006 | 04:33 PM
JDK's Avatar
JDK
Here's a few picture's of my set-up installed on the turbo.
Old Mar 31, 2006 | 05:14 PM
GoRacer's Avatar
Speed Mach Go Go Go
I will have mine cut and do an elbow although mine does clear by a few MM and I didn't know 15deg should be the max angle (good to know). I also want to run SS lines, so will acomplish that as well as more clearance. On the intake oil line side I replaced the "L" fitting with just a short strait aluminum one. My other fittings had bad threads, so I replaced those with aluminum ones to. I also got a blanket from Australia and will heat coat the housing and I have a heat shield all for the hotside. I can't find the pics but will post when I do.
Old Mar 31, 2006 | 05:38 PM
atihun's Avatar
Jim,
Where did you pick up that oil drain pipe? I really like that one...
Thanks,
Attila
